3 Point Attachment Switching not enjoying.
   / 3 Point Attachment Switching not enjoying. #62
   / 3 Point Attachment Switching not enjoying. #63
You have choices:
1. Modify all of your implements to fit the framed QH. Lots of welding, bending, adjusting, and adding materials. When you get a new implement it likely will have to be modified as well.
2. Forget the QH and go back to manual hook-up. It will go faster with practice.
3. Spend a fortune and get the Deere I-Match. Figure to spend more for each attachment.
4. Get a Pat's Easy Connect and be done with it.
   / 3 Point Attachment Switching not enjoying. #64
Ok, did my first change out today of attachments (Box Blade to 3 Pt Receiver Hitch). Just a quick briefing I am new to SCUT'S and 3point attachments! Ok is it really as much as a pain as I just experienced? I figured you pull the pins drive off attach the next. Seems like you have to twist turn and maneuver your attachment to get weight off of the pins. Am I missing any tricks? Should I be running out for this iMatch system? Doing all kinds of stuff around the house. I want to be able to be box scraping, be done with that, throw the 3 point receiver hitch on to trailer stuff around the property, quickly switch over to a heavy ballast to start moving boulders.
Just not looking to break down a schedule on when I am doing what because that attachments aren't as easy to get off as I thought. And I could see myself saying "Man I'm not dealing with switching out attachments, I'll do that next week."
Don't you like to use loud foul language and kick sh*t of the thing sometime.
Alexander Equipment - Founder of the Delta Hook Rapid 3 Point Hitch System is the least pain if you have the money to buy adapters for your implements.
   / 3 Point Attachment Switching not enjoying. #65
Greasing the ball ends in the lower links helps me. Having a 3-pound hammer and a 4' long crowbar helps me. Being on relatively flat ground helps me. Doesn't mean it's not a pain in the rear, but at least it's a pain that only lasts five or six minutes.
Haven't gotten around to it yet, but sooner or later I imagine I'm going to make myself some dollies. The idea of just rolling the implement into place behind the parked tractor sure sounds good.
xtn
   / 3 Point Attachment Switching not enjoying. #66
Was out wrestling a post hole digger the other day.:laughing: The foul language was flowing... for a good 20 minutes.. I'm sure I pulled my back out fighting that thing.
I think I might have found the trick is to drill it in the ground standing upright and unhook it.. and then it'll be less of a bear to get on again..
I tried talking my wife into just letting me buy a tractor for each implement :laughing:..
   / 3 Point Attachment Switching not enjoying. #67
Well I don't need the practice hooking up implements to get better at it I have been hooking up 3pt implements since I was 9 yrs old or younger (like 44 + or - years) so that's not going to get any better.
I am not going to weld, bend, cut, adjust, and modify, to the extent you are talking at least. Some modifications are ok, but too many just don't seem worth it.
I don't have a concrete area to use dollys as suggested.
I guess pats type connections are the only way unless I stay with what I have the old fashion back up, push, pull, pound, cuss and so on. I just wanted to know which way I was going to go before I bought the hydraulic center link because if I go with the pats it will change.
   / 3 Point Attachment Switching not enjoying. #68
The Carters work pretty well too.. I have a set for sale. I don't need them any more after getting the Kioti with the telescoping links and side sway adjusters. Also you could make a set pretty easy if you can work 1 inch thick stock.
James K0UA
   / 3 Point Attachment Switching not enjoying. #70
RIGID TOOLBOX (A52472)
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
Tropical Trailer 6'x12' Single Axle Trailer (A50121)
Tropical Trailer...
Rhino MD-84 (A50121)
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
