Zebrafive
Super Member
Here are some pictures of my hydraulic top link. I don't have any experience with these. What do you think?
Thanks,
Island Farmer
What's the bore? I am planning on 3" for the 6415. Needs some green paint!:laughing:
Thanks,
Island Farmer
Hi Zebrafive,
I am in kind of a hurry at the moment. I can check later, but I believe that the bore is 3".
Island Farmer
Zebrafive;2838785]Have you considered getting the wheel centers drilled for wheel weights?
Would this be a solution? Or do you want to get away from 34" wheels?
Would you gain any steering angle switching to 13.6s vs 14.9s? If so I would switch. 14.9s seem overkill on a 5000 series. If you only switched to 13.6s where that leave your overrun percent? still in range?
For the rears I doubt you would notice the difference between 18.4 30s or 34s. I think the 2" lower would make it more stable, but doubt you could tell.
Why no RimGuard? It would be my first choice for rear wheel weight. I know once it's in you can't remove and replace like wheel weights, but who does that? People put wheel weights on and leave them too.
Have you checked the ballast requirements for the loader? Sometimes no wheel ballast is not an option.
My guess on why a tire combo is not offered would be lack of demand. Most people do not do the research you have done, they just buy what is offered.
I don't think there is a choice in the Multicoupler mounting (unless you are building your own bracket) I mounted mine with the handle out because that's how Deere did it on the 640 loaders. I like the way shown in post 251 with the handle forward. It sticks out less and being right handed it looks like the swing of the lever would be easier for both couple and uncouple. IIRC I'll gain almost 3 1/2" clearance if I turn mine 90 degrees (lever forward)
I even took the handle off and straightened it to gain clearance. (see the bends in first picture)
I actually like the guard in the first picture the best, it's taller and will protest the hood better. You should see the second pictured guard without the mesh brush guard installed. Do you have a picture of Caledon Hills guard?
JD offered a HD guard for the 673 loader that I liked better than the one that came on my 6415. They offer the mesh guard for it too (on my wish list). So I bought the guard and swapped. Weighs about 50lbs more than the original one.
It has larger side plates. A 2" x2" crossbar, the folding part is larger (taller), and the latch has been moved from the right side to the left (same side as the hood latch).
