push button p.t.o. engagement
   / push button p.t.o. engagement
MHarryE said:
Unlike another L5740 owner who posted above, my L5740 engagement is abrupt. It is a multiple wet disk clutch with electro-hydraulic control. Push the button, hydraulic flow goes to the spring disengaged clutch and pushes the plates together. I start my mower at low idle and bring it up. If I do want a very easy engagement I have the foot clutch that controls all power flow from the engine to the back end so I can feather that but I find the push button at low idle is smooth enough.
Is kubota the only mfg. That has a foot clutch on a hydro tractor?
   / push button p.t.o. engagement #12
Yesterday, I test-drove a Bobcat CT225, and it had a foot clutch for the PTO. I assume the others in the CT2XX line are the same.
   / push button p.t.o. engagement #13
Some manufacturers have it both ways and different models have a clutch while others don't. Left and right brake pedals also change within a single brand depending on model. It would be nice if tractor controls were standardized at least to the level that automobiles are, but that's a pipe dream.:(
Looks like if I buy a tractor with no foot clutch I had better replace the shear pin with a slipclutch, just to make it easier on the tractor pto, probably should do it no matter what.
   / push button p.t.o. engagement #15
Well, after spending the day with my Bush Hog, it was not as gentle a start as I had with my old manual tractor. I started it at a low idle, but it still gives a pretty good jolt. I use really soft shear bolts and didn't break any, so it must not be too bad.
   / push button p.t.o. engagement #16
That was my impression also.. No sheared bolts, but I could have started it smoother with a clutch... But we ain't got no stinking clutch:laughing: It seems Ok, and it sure is convenient.
James K0UA
James K0UA
Well as I look for a tractor, since rotary mowing is something it will be doing alot, may have to put a plus in the comparison column of the tractor that has a clutch that can be used to feather the pto in, just won't be a deal breaker.
   / push button p.t.o. engagement #18
The Massey's have an electric over hydraulic clutch for the PTO also, but their fancier tractorss have a "modulation" button so you can control the flow of the hydraulic oil to the PTO clutch plates for a smooth start with high inertia devices like a rotary cutter.. the Kioti works fine, it is just I could do it a little smoother by feathering a clutch. But it is not bad.
James K0UA
James K0UA
Haven't looked at Masseys what models have that feature in the 50 hp range. Just read on the Mahindra forum of a 3035 breaking the pto shear pin when engaging a rotarymower. My main concern would be if hard on the tractor pto system if it is that abrupt. Two of the tractors I am looking at now have the electric engagement
   / push button p.t.o. engagement #20
All I can say is no broken shear pins here.. it is abrupt, but it is not like a big bang.
James K0UA
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
John Deere 5045E for sale Auction
John Deere 5045E...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
