If I were a JD engineer, I would......
   / If I were a JD engineer, I would...... #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
....Make a bottle / cup holder that could retain a standard bottle of water or coffee mug when operating over rough ground.
I must have lost at least 20 bottles of water and several coffee mugs because the blasted fender holder / pocket is not deep enough or sized correctly to hold standard mugs and bottles when I am working on my land. Today I lost three. A deeper pocket would help ALLOT. It aint rocket surgery.
How about a QD holder on the ROPS that could hold a 12" crecent wrench so I can easily adjust my top link. It's impossible to carry a big wrench in the fender box.
How about a few more tips for JD engineers to improve upon?
   / If I were a JD engineer, I would...... #2
My top link adjusts without having to use a wrench.
And a hanging bottle holder works great. ;)
Sorry to hear you are losing bottles. Must just get frustrating after awhile.
   / If I were a JD engineer, I would...... #3
My top link does not require a wrench either. There are pins welded to both sides of the top link's barrel for adjustment by hand. BeenThere and I have similar tractors, his being a 4300 and mine, a 4400.
I'm very surprised foggy's 3320 doesn't have this...
As far as the cup holder, as hanging botle works well, or you could rig something up on the loader's mast. I don't know about the 300/300cx loaders, but the 430 loader has an access hole (for greasing a zerk) a couple inches from the top of the mast.
   / If I were a JD engineer, I would...... #4
....start using far less metal to build lawnmowers and tractors.
   / If I were a JD engineer, I would...... #5
The best bottle I've seen that will stay in the cup holder of our Kubota L3940 is a refilled 32oz Gatorade bottle fits snuggly in our cup holder when turned upside down.
   / If I were a JD engineer, I would...... #6
I hope you arent serious with this thread
Yes, I'm serious. I use my tractor....I dont just mow lawns or wash the tractor. I realize I can find solutions....but I got other fish to fry. "Little" stuff like losing my water bottle is annoying.
Yesterday I put ten hours on my clock tilling about ten acres.....and it was warm and dusty work. I keep a small refrigerator at my shed with bottled water and lose em all too easy. My land is ROUGH. I really dont want to re-engineer this little stuff....or buy a different solution. A deeper pocket or better retention would solve things. I suppose I will look for a hanging water bottle when time (or memory) permits. :laughing:
Regarding the top link....I have two "U" shaped rods welded to either side of my top link....but what about the jamb nut? Still takes a wrench on mine...and usually some kind of bar thru the loops on the top link.
Yesterday I had two crow bars, a 5 lb hammer, a loper, a big crecent wrench, and assorted cutters and pliers bunge corded to my tiller - for field maintenance while tilling new land. Hard to easilly stow this needed stuff.
   / If I were a JD engineer, I would...... #8
You might try one of those foam cup insulators. They have about half inch thick sides that'll probably snuggly hold your brew in place.
   / If I were a JD engineer, I would...... #9
I think the point of the post is to bring out some of the short comings of the model.
While most of these are creature comforts, I agree. I would like a more comfortable seat that would keep me pushed forwards instead of leaning back.
A little better safety seat switch that doesn't shut the tractor down when you shift your weight would b nice.
Being able to start the tractor in gear would be nice as well.
NOW were tracking. I think there is always room for improvments. :thumbsup:
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
