Tarp for Wood Piles???? What do you use thats black?
   / Tarp for Wood Piles???? What do you use thats black? #21
I get the thicker tarps at Lowes. They are brown on one side and silver on the other. I cover so that the brown side is up. I am pretty sure they had long thin tarps made for covering wood piles. I use the tarps that are about 10'x12'.
Later,
Dan
   / Tarp for Wood Piles???? What do you use thats black? #22
most of my wood is on 3x3 pallets right now. I use Heavy CLEAR PVC from comes in 3 1/2' x 7' I cut in half to cover 2 stacks.
I'd love to find some rubber roofing.
I work hard for every BTU of firewood, and even slightly damp wood steals BTU's. But I live in the woods too, so limited sun and wind.
   / Tarp for Wood Piles???? What do you use thats black? #23
I prefer a wood shed but this guy does nothing but pile his.:thumbsup:
   / Tarp for Wood Piles???? What do you use thats black? #24
I just use the lumber wraps from local lumber yards. Its white on one side and black on other. I only cover the top since I want to keep snow and rain off and I do put bark side up. Makes it easier to work with in middle of sub zero temps and I dont have to bang things apart to grab wood. I use the black side up and it works good, If I see white side up - it just means it been blown over/off.:laughing:
   / Tarp for Wood Piles???? What do you use thats black? #25
That is a lot of firewood!!! :confused2: :confused2: :confused2:
I guess he is a wholesaler?
   / Tarp for Wood Piles???? What do you use thats black? #26
I also palletize my wood. Stack as much on as my BX25 will lift with forks on the 3PT and then band it down w/fiberglass banding. Easy to move and it does not come apart when I hit a bump. I just cover the top of the rows so it ventilates, weight it down with whatever I have handy. Plan do do about 8 cords this summer/fall. Probably about 10-12 pallets depending on type of wood (weight). I cut up everything 1" and larger and stack. I use pallet boxes to store all the short ends and pieces for kindling. I have fir, hemlock, madrone, oak, maple, birch, apple, pear, cherry, and cedar laying ready to split and stack.
Ron
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
Toro Ground Master 4000D (A56857)
Toro Ground Master...
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2023 Kubota SVL97-2 Compact Track Loader (A56435)
2023 Kubota...
