If you were buying a new trailer
   / If you were buying a new trailer #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
What features would you add or eliminate? I can get a custom built for 5% more than a factory unit.
I am going to buy a new trailer for my CUT, FEL and BH (at least 7000# net). It needs to be at least 20' long and bumper pull. My tow vehicle is '06 Chevy 2500HD, Duramax/Allison tranny.
Looking for your likes and dislikes, ideas for ramps, tie downs, decking, tires, axles, hitches, paint, etc!!
Help me build that perfect trailer!!
Pictures of your rigs would be great!!
   / If you were buying a new trailer #2
- Lots of rope hooks; my trailer gets lots of use besides hauling the tractor. Pipe, lumber etc.
- rear jacks/stabilzers
- guards for the tail-lights
- brakes on both axles
- an extra 2' more than you think you need
- spare tire, mount, and lug wrench(the one for your truck probably won't fit...)
Good ideas
What about legs on ramps vs jacks or stabilizers?
   / If you were buying a new trailer #4
Good ideas
I don't like the stabilizers/jack, they are a hasel in my opinion. The one on the ramps are there automaticly when the ramp is lowered. plus all the one trailers i have seen with jacks they stick up and can get in the way.
I second the 2ft more. I fill mine (20'+2') easyily with tractor and brush hog. The only thing i would add to mine are more D-rings for tieing down. I put wooden sides on mine and all the stake pockets are being used, it did come with 2 rings on the front of the trailer though. Ill post some pics later.
I like the +2 idea. that could be a dovetail so ramps would be shorter and easier to flip up. Anybody have spring assist ramps?
   / If you were buying a new trailer #6
I like low flat deck with slide on ramps.
Chris
   / If you were buying a new trailer #7
Lots and lots of tiedowns, and ones like this scattered around the floor:
Floor Chain Tiedown - Grade 70 chain - Load Binder Chains
Floor Chain Tiedown - Chain Binder - Transport Chain
Bruce
   / If you were buying a new trailer #8
these are not real good pictures but you can see how my ramps are held up or they will fold flat to make the dovetail a flat deck.
Kubota RTV500 (A47384)
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
