Subsoiler/Middle Buster
   / Subsoiler/Middle Buster #21
I have, should say had until today, the KK XB combo unit. Purchased mine from TSC with County Line name but is exact same as KK. First to note this is dimensioned to fit a SCUT, has narower lift point width and lower top link height. I modified it to fit my Quick Hitch, no problem until today when cutting a ditch through the yard for the TV dish cable.
Below is pictured what can happen when it meets an imoveable object with too much traction. Snagged a stump I had cut off below ground level few years go and forgot about it. I can't blame it all on the subsoiler. It was doing a great job on roots and I did stop when it first hit the stump but thinking it was another root I raised it a few inches and tried again. That time the tip of the tooth was against the stump and just folded it back.
Think I will upgrade to a little stronger version.
   / Subsoiler/Middle Buster #22
Excellent evidence that a CT225 is not a SCUT even though it puts out the same HP as a BX25.
   / Subsoiler/Middle Buster #23
i was thinking of getting a middler buster from tsc a cheap one not if a 225 bc can do that my l3800 kubota will im guessi do more to it who makes a better one i didnt wanta spend an arm n a leg i only use it for my strewberry patch
   / Subsoiler/Middle Buster #24
I recall Leinbach makes a subsoiler/middle buster that is good quality without being as expensive as the Fred Cain type. At least that is what my fading memory tells me.:confused2:
   / Subsoiler/Middle Buster #25
   / Subsoiler/Middle Buster #26
   / Subsoiler/Middle Buster #27
From what I've been seeing and reading here you can probably go by weight. The 100lb units are tough and the 50lb ones aren't as tough.
   / Subsoiler/Middle Buster #28
I use the middle buster from TSC. It is not the subcompact version that has the subsoiler blade. The reason I went with this one, was because I had read the reviews on TSC about the smaller version breaking like in the photos in this thread. I have very rocky soil in New Hampshire with large chunks of granite, and I have hit several of them, and the middle buster actually pulled them out of the ground without a mark on the unit. They redesigned it a bit, and TSC's 3 point equipment is made by King Kutter for the most part. Again, I have been very happy with this You can see the design differences between this one, and the lighter orange model that they sell. I would recomend it, and they go on sale a lot.
CountyLine Middle Buster - 2128228 | Tractor Supply Company
   / Subsoiler/Middle Buster #29
NHmitch
Nice Bolens
I worked on my home-made trencher today.
I found that the operation kept working better as I brought the tiller blade back so I put a second bolt which gave me a point just less than the furthest that it would reach down and then two more settings. Just welded on a 10mm bolt on the side.
I have noticed that about an inch has been worn off the blade I think I will turn it around.
I'm currently looking at that middle buster and subsoiler. Lots of stumps in the ground and I'm sure I'll be finding them.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A57024)
2014 Doyle Dry...
PULL BEHIND SHEEP FOOT COMPACTOR (A52707)
PULL BEHIND SHEEP...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 PETERBILT 567 FLATBED DUMP (A57880)
2018 PETERBILT 567...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
2015 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2015 CATERPILLAR...
