metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil #51
luckilly that governor is real close to the oil sump.. likely it all fell out and went safely to the bottom.. like the titanic.. :)
   / metal piece came out of oil pan when changing oil #52
I tend to agree, everything may be ok unless a piece somehow managed to find it's way into the aluminum oil pump gear, which could be easily damaged.
   / metal piece came out of oil pan when changing oil #53
you'd already know by now.. same with the timing gear...
   / metal piece came out of oil pan when changing oil #54
G'day I want to know where all the balls went?????
Jon
Here are some pictures of some progress ,there were 2 balls left in the assembly and the remaining 8 were at the bottom . Things look good as far as no major damage to casings and gears. A little play in the oil pump gear between teeth on crank teeth.
   / metal piece came out of oil pan when changing oil #56
yep.. I figured they'd be inthe bottom...
everything came apart pretty good ,now I should clean everything up.Thanks .
I did notice a newer gasket sealer was used . This has been apart befor . I'll have to check out a gasket kit ,governor assembly ,case seal
   / metal piece came out of oil pan when changing oil #60
prev owner may have 'serviced' it and not put it back together correctly.. no keeper or something..e tc..
I just love taking something apart.. especially something delicate or expensive/difficult, and seeing rtv extruded out the sides of the case cover.. :)
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2007 Chevrolet C6500 Landscape Dump Truck (A55788)
2007 Chevrolet...
Duetz Power Unit (A50120)
Duetz Power Unit...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
