metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil #51
luckilly that governor is real close to the oil sump.. likely it all fell out and went safely to the bottom.. like the titanic.. :)
   / metal piece came out of oil pan when changing oil #52
I tend to agree, everything may be ok unless a piece somehow managed to find it's way into the aluminum oil pump gear, which could be easily damaged.
   / metal piece came out of oil pan when changing oil #53
you'd already know by now.. same with the timing gear...
   / metal piece came out of oil pan when changing oil #54
G'day I want to know where all the balls went?????
Jon
Here are some pictures of some progress ,there were 2 balls left in the assembly and the remaining 8 were at the bottom . Things look good as far as no major damage to casings and gears. A little play in the oil pump gear between teeth on crank teeth.
   / metal piece came out of oil pan when changing oil #56
yep.. I figured they'd be inthe bottom...
everything came apart pretty good ,now I should clean everything up.Thanks .
I did notice a newer gasket sealer was used . This has been apart befor . I'll have to check out a gasket kit ,governor assembly ,case seal
   / metal piece came out of oil pan when changing oil #60
prev owner may have 'serviced' it and not put it back together correctly.. no keeper or something..e tc..
I just love taking something apart.. especially something delicate or expensive/difficult, and seeing rtv extruded out the sides of the case cover.. :)
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
