How To Remove Lift Cover - Ford 3000
   / How To Remove Lift Cover - Ford 3000 #21
I primed the pump and am back in business. Another question though, after removing the bleeder plug the fluid that eventually came out was milky, about the color of hot chocolate. That means water right? I let this run for a good minute thinking the contaminated fluid would work it's way out but it never stopped. Since I emptied the sump and refilled with new fluid I cannot figure out where the water came from. At this point the tractor had not even been outside. For as long as I let it bleed I would have thought the old fluid from the lines and pump would have flushed out.
   / How To Remove Lift Cover - Ford 3000 #22
Can someone tell me where to purchase the suction filter with the metal mesh.
Thank you
TydeFarm
   / How To Remove Lift Cover - Ford 3000 #23
You may not get many replies because this post is old. Check the date of the last post. By the way welcome to TBN. The part you're looking for can be found at any Ford/New Holland dealer or here:
Ford Hydraulic Filter - C5NNN832B
   / How To Remove Lift Cover - Ford 3000 #24
try messicks online..
   / How To Remove Lift Cover - Ford 3000 #25
TydeFarm//
C5NNN832B is the return filter (#50) in diagram. The suction filter is #60 in the attached diagram.
60 1 C5NNN994M FILTER Filter & Pipe Assy., Suction, 2000, 3000, Except 3550, Years: 01/01/1965-03/31/1968
60 1 C7NNN994B FILTER Filter & Pipe Assy., Intake, 2000, 3000, Except 3500, 3550, (Not Shown), Years: 04/01/1968-01/31/1975
60 1 C5NNN994S FILTER STRAINER Filter & Pipe Assy., Suction, L/Independent PTO, 3550, 4000, Replaces C5NNN995R, (Not Shown), No Longer Serviced NH-E., Years: 01/01/1965-03/31/1968
60 1 C7NNN994A FILTER Filter & Pipe Assy., Intake, L/Independent PTO, 3500, 3550, 4000, Replaces C7NNN994C, (Not Shown), Start Year: 04/01/1968
60 1 C5NNN994L FILTER Filter & Pipe Assy., Intake, W/Independent PTO, 3550, 4000, Replaces C5NNN994E, (Not Shown), See Service Bulletin 4T Jan. 1970 (North America)., Start Year: 01/01/1965
So, if your tractor is a 3000 and earlier than 03/31/1968 it is C5NNN994M. From 04/01/1968 it is C7NNN994B.
As said, try Messick's. You could also find dealers through an internet search for the numbers.
   / How To Remove Lift Cover - Ford 3000 #26
Thank you
TydeFarm
I gave you the wrong number. HakanTh correctly has the right info for you, see post below. Sorry bout that only trying to help.:eek:
   / How To Remove Lift Cover - Ford 3000 #27
I am having to remove my lift housing cover on my Ford 5000. I tried to lift my lift housing cover and would not release from the right side. Is there a bolt or something else that is holding the housing in place? ... All bolts were checked for removal and all was fine... Just some reason I can not get the right side to lift and didnt want to go any further or apply any unusual force breaking something. ANY IDEAS? ..
Thanks!
   / How To Remove Lift Cover - Ford 3000 #28
Is there a diagram on how to put it back together?
   / How To Remove Lift Cover - Ford 3000 #29
there is an exploded diagram in the service and parts manual.
   / How To Remove Lift Cover - Ford 3000 #30
The filter on the right side has a threaded pipe that screws into the cylinder in the top deck. I cracked the housing trying to remove mine 2 years ago and it was a $2000 repair. I had the cylinder housing repaired at a machine shop, and the tractor is still torn down awaiting time to put it back together. The d#$%@ I&T manual does not show this.......
Informational Lot - Shipping (A53473)
Informational Lot...
2018 John Deere 1653 (A53472)
2018 John Deere...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
