New here w/ Ford 861
   / New here w/ Ford 861 #101
4 cyl 2000 cover will fit. ie.. 1955-1964 covers will swap, on gear type machines. find out if that 'early' 2000 is a 4 cyl or a 3 cyl.
simple amazes me that people won't list the darn year of the parts they are selling. the machines have plenty of provisions for iding their year/model at most basic.. and year to year based on looks and options on the machine, if not sn and date code...
I guess he doesn't know the year---It is from a 4 banger though. Are there any tricks to the swap I should know about? Lever position, fluid drain etc? I'll probably try to make a new gasket from a box of cereal...
Thanks
   / New here w/ Ford 861 #103
if it's from a 4 banger that had a gear trans it will fit.
probably take you 5 minutes to swap it.
gasket paper.. cerial box.. and in this case.. this is the only place I'll 'allow' rtv usage.. permatex #2.. etc. it's a non pressurizes sump. etc.
pul the bolts.. pop the cover off, pup new cover on with gasket or goop..aligning pto lever stick bolts in and go.
no tricks to thins one. 100% straightforward...
soundguy
   / New here w/ Ford 861 #104
2 closest major cities are ocal and orlando.. I'm between them. bunch of lil popcorn cities scattered all around.. wildwood, belleview, summerfield, lady lake, leesburg, weirsdale, eustis, pedro, umatilla, altoona, crystal river..e tc. all them are within 1hr drive, with ovcala at about 30-40m and orlando 45m-1hr if i hit the turnpike...
Sorry for late reply - been traveling. Yes - I know the area well - Live in Lake Mary/Sanford. I've got a 58 Powermaster that is in pretty good shape but I've got a rear wheel that has rusted and I don't know anyone that sandblasts - hoping you might have a recomendation or two...
Thanks
   / New here w/ Ford 861 #105
break it down and dismount. if the rim is stil structural, wire wheel it and then use a rust converter chemical. then clean that up.. prime and paint. i reccomend using an epoxy paint. you can even get that in a spray can. if the rim is gone.. and you don't have a donor to cut up.. I'd just find a new one. or a good used one..
   / New here w/ Ford 861 #106
Thanks - it was a calcium leak that got it - I'm hoping it will be OK - it's got the adjustable rim style.
   / New here w/ Ford 861 #107
which ones. could be many types. some more replaceable than others..
Well, the PTO cover went on without a hitch---easy. But while working there I noticed the lift cover had a crack. Want to get your opinion soundguy---it lifts only at last half of quadrant and leaks down fairly quick under heavy load, so I know I'm going to have to work on it at some point. Do you think the cover is weldable? It looks like there's two cracks---one that was welded on top (and may have recracked under the weld), and one on the side that looks newer. I don't know what kind of work that area gets. Maybe a replacement cover is necessary?
   / New here w/ Ford 861 #109
the leaking down under load is usually a lift piston oring. might need to hone the cyl as well. lift cover kit with gaskets and a handfull of orings is about 15$.. has all the orings for under the cy; and option cover.. etc.. only lifiting at the end of travel is usually indicative of a worn cam follower pin and / or worn cam and linkage out of adjustment. there are alternate adjustment instructions in the service manual to adjust the lift without using the special nuday tools.
the cam pin can be pressed out at home using a socket and pin punch/drift.. and a ne wone mad of a broken drill bit stem.. or a real dowel pin.. cam usually wears in profile so you have part of a surface as a witnes to weld back up to then grind and file to correct profile.
the area of that damage is outside the hyd ports.. so it COULD be welded.. but.. it's in a spot that carries all the weight.
if I did weld it I'd do it witht he cover off and the rockshaft out. weld from outside and underside.. and inside the bore.. then hone out. would have to vcut the cracks and clean oil out of them with a torch.. would have to pretty much pull all the hyds components. might be easier to find a good lift cover.. though it is for sure weldable with a lil technique and patience. I've seen a factory weld patch on an 8n lift cover that came out of ford factory.. so i know it can be done...
i know a guy that sells surplus parts.. he has a cover for 80$ plus shipping. might be easier to go that route.
fair guy to deal with. I've bought tons of parts from him over the years. all good results.
best of luck either way.. you got options..
Hydraulic and Lift Parts For Sale
Thanks for the link. I think that's the way to go. I'll let him know you sent me...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
