My 1966 Massey 135 Tractor (Pics)
   / My 1966 Massey 135 Tractor (Pics)
The following are pictures of the oil pan after it was sandblasted and primed.
The following is a picture of the fan shroud after it was sandblasted and primed.
The following are pictures of the battery box assembly (194185M92 - Platform Assembly, Battery and Instrument) after it was sandblasted and primed.
The following are pictures of the front axle support after it was sandblasted and primed.
   / My 1966 Massey 135 Tractor (Pics) #165
Wow! Looking good. Looks like you primed a still somewhat assembled structure in your last image. Any reason to stop disassembly there?
Battery box assembly, not front axel support.
   / My 1966 Massey 135 Tractor (Pics) #166
that steering bolster is solid...
   / My 1966 Massey 135 Tractor (Pics) #167
Upon furthee scrutiny iy appears that the bolts are only protecting the threads and not holding anything in place. I think...
Like Soundguy, I also thought you meant the front axle support, which is a solid (and heavy) cast steel piece.
Now that I know you meant the battery box assembly I can say that it was disassembled as much as possible, without cutting the welds. The bolts, used to attach the voltage regulator, were left in place to protect the threaded holes, and so I could prime the bolts at the same time. Leaving bolts in place also reduces the possibility of losing them or losing track of where they went.
If you look just to the left of the bolts, there are 4 small screw holes, which are used to attach the serial number plate.
   / My 1966 Massey 135 Tractor (Pics) #169
Wow Massey,
That is a really good. I hope to someday fix mine up that good. I cant wait to see the top coat and all back together. Thank you for sharing.
v/r
Mike
   / My 1966 Massey 135 Tractor (Pics) #170
Like Soundguy, I also thought you meant the front axle support, which is a solid (and heavy) cast steel piece. Now that I know you meant the battery box assembly I can say that it was disassembled as much as possible, without cutting the welds. The bolts were left in place to protect the threaded holes, and so I could prime the bolts at the same time. Leaving bolts in place also reduces the possibility of losing them or losing track of where they went..
Thank you for taking the time to explain. If I lived nearby I drive you nuts with questions and you'd be looking to get a restraining order...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
John Deere 60 Tractor (A59814)
John Deere 60...
2014 Jeep Grand Cherokee SUV (A56859)
2014 Jeep Grand...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
125cc EGL Motor Dirtbike (A57453)
125cc EGL Motor...
