York Rake--Are they any good!
   / York Rake--Are they any good! #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Is this unit worth $1000? It is a York 6 ft. model RS with optional scarifier, gauge wheels and drop-down blade. Ad says it has never been used but the paint looks tough.
   / York Rake--Are they any good! #2
The best
but ofter too high dollar
   / York Rake--Are they any good! #3
Independently adjustable wheels with the "quick crank". That is a deluxe option I have not seen before. Plus the drop-down grader blade... hhmmm. If it is in decent shape (i don't mean the paint) as far as: no bent tines and things like that, I could see it fetch that kind of price in my neighborhood.
   / York Rake--Are they any good! #4
You've got at todays prices $1146.00 for the basic RS rake and $934.00 in options, the castor wheels and the scarifier. If you haven't already, go to York Landscape Rakes for Tractors and ATVs, Rotary Brooms, Stone & Rock Rakes, Sweepers, and Scarifiers Manufactured by York Modern Corporation and look up the RS model. It's one of the lighter rakes built for 10/20 hp tractors so you're right in there. What it doesn't have is the standard factory built angle platform (like my RI model) for a hydraulic cylinder, but it will manually adjust to five preset angles. I saved more than half of what York wants for their hydraulic cylinder kit by buying the parts from TSC. The two cranking rods I think are aftermarket modifications probably to work a road crown and if so, all the better.
If you have a set of remotes, take a close look at the rake to see if it would be possible to fab up a hydraulic angle platform, I sure like mine and use it a lot-much easier than hopping on and off of the tractor while making winrows, ditching and road crowning.
Personally, I would pass it over due to the lack of the hydraulic option but I do think you have some dickering room here.
   / York Rake--Are they any good! #5
Offer $800 and leave your name,if owner doesn't bite keep searching.
   / York Rake--Are they any good! #6
I just looked it up on CL and its down to $850
   / York Rake--Are they any good! #7
Looks very handy. I have been looking for a standard 3 pt rake, but one with wheels and independent adjustment would be sweet.
I figured the two crank rods were a part of the standard design but this may be a fairly old unit. Ad says that it has "never been used".
I could add a cylinder to angle adjustment. I would think that the drop-down blade would be handy for moving snow.
   / York Rake--Are they any good! #9
Beg your pardon-you did say drop down blade-why was I thinking it had a scarifier?
If it has never been used, why am I seeing what looks like an even rust line a couple of inches up from the bottom of the tines? Might just be a shadow line. Only a visual inspection will tell.
It has both, the drop down blade and the scarifier.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 Yongfu Scooter (A59231)
2019 Yongfu...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
