1st rule of welding, is?
   / 1st rule of welding, is? #21
Also If you don't like your son wearing Sandles have him watch you weld. Haha
   / 1st rule of welding, is? #22
first rule?
Leather boots!! lol. Slag between the toes sucks.
   / 1st rule of welding, is? #23
first rule?
   / 1st rule of welding, is? #24
Make sure your coveralls have no holes!
Nothing like carrying ground clamp and electrode and having said electrode find the hole in your coveralls to touch your sweaty skin while the welder is powered up...
   / 1st rule of welding, is? #25
surface preparation is half of the result.
(that means either removal of rust, paint or tar on the surface, but sometimes also cutting a Vee for proper penetration. I allways try to grind a V before, then weld with a flat surface. Cutting a V is easier than grinding a bead flat. And it isnt really helpful if, especially with light welders on heavy steel, you put a bead on top and then grind it down again...
   / 1st rule of welding, is? #26
Never chip a weld with your mouth open! Unless you like slapping yourself with dirty gloves and making funny fart sounds!
   / 1st rule of welding, is? #27
Heh-heh ... that's funny.
   / 1st rule of welding, is? #28
Now that's funny right there!!!
RC
   / 1st rule of welding, is? #30
I thought the first rule of welding was you do not speak of welding.... or at least don't speak of the stupid mistakes you've made that no one was around to see.
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
CFG Industrail MX15RX (A53317)
CFG Industrail...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
207270 (A52708)
207270 (A52708)
