1989 ford 1920 engine acceleration
   / 1989 ford 1920 engine acceleration #1
achallie
Member
Have a Ford 1920 that I am putting back together after several years of sitting idle. I have it up and running and am working out some hydraulic problems, however, I have one problem which I am uncertain about. I have it up and running and it seems to idle fine but after a while of idling it will just accelerate to extremey high RPM's and then just die. Any thoughts?
   / 1989 ford 1920 engine acceleration #2
Is it possible there is gasoline mixed with the diesel?
Mike
   / 1989 ford 1920 engine acceleration #4
Has the engine been running away since you reassembled the injection pump or is this a new symptom?
Mike
Hard to say since it hasn't run in several years .
   / 1989 ford 1920 engine acceleration #6
If the engine runs smoothly, I would think that the governor linkage is not attached to the injection pump correctly.
Mike
I'll check into that. It's pretty strange. It may idle fine for 10 or 15 minutes and then just take off to excessively high RPM's. To the point that I have to kill it for fear of it throwing a rod or something.
   / 1989 ford 1920 engine acceleration #8
I think the governor is internal to the injection pump. It sounds like soemthing is sticking within the pump or the governor is not working correctly.
   / 1989 ford 1920 engine acceleration #9
The governor is in the timing cover.
Achallie, does the throttle have any affect on the rpm s?
Mike
Mike
No it doesn't but it seems I have a new problem. The steering valve at the end of the steering column has a cracked housing. New Holland is showing 1600 bucks for that thing..don't know what they've been smokin...Any have a good source for used parts?
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
10' Feed Bunk (A50515)
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
(INOP) TAKEUCHI TL12R2 SKID STEER (A51242)
(INOP) TAKEUCHI...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
