Ford8n Antifreeze
   / Ford8n Antifreeze
so i should just replace the water pump and all is good
   / Ford8n Antifreeze #92
boy.. hard to follow this thread as we are talking about a case sc in a 8n thread.. :)
   / Ford8n Antifreeze #93
What?? are you the guy with the blown head or what? Im with sound guy this post is all over the board now. I guess your the OP as you have 8n listed in the side?
But NO replacing a water pump will not fix bubbles in the Rad. Now if this is not what your asking forgive me, but this seems to be turning into a post on just about anything tractor related?
Edit: your the same guy i see! So my answer stands about the waterpump. The water pump is unrelated to a blown head.
There should not be BUBBLES of air (combusion gasses) inside your radiator, its a sealed system. Yes you can have turbulance and small air bubbles if you have a low radiator and for somereason sucked air into the water pump but you probably wont notice them unless your draining and refilling your Rad. The bubbles are from a blown head gasket and when the piston compresses it forces gasses around the bad gasket into the cooling jackets and out into the radiator where they bubble up.
   / Ford8n Antifreeze #94
the confusion is that he apparently has a case sc or similar with a water pump shaft seal going out.. leaking water and sucking air into the rad and he has merged the topics... :(
   / Ford8n Antifreeze #95
I was thinking that since he mentioned a water pump that there was a possibility of sucking air and causing bubbles that way. But i did miss where he said he had a leaking shaft on the water pump, which is why i said what i did.
Yea this is getting confusing. Best if we are to keep talking about this to start a new thread.
   / Ford8n Antifreeze #96
yup! i agree. hard to tell what's bouncing back and forth after a day has past .. etc..
   / Ford8n Antifreeze
i am in need of a new radiator cap for my 50 ford 8n the one i have now does not have a spring in it like the new one do and it only has one hole in it is it ok to use the new radiator cap with 2 holes and spring?
   / Ford8n Antifreeze #98
a 4psi cap is what you need. tractor supply carries one. any one that firts and is 4 psi is fine.
   / Ford8n Antifreeze
them caps at TSC ARE Junk and flimsy! anyhow the governor on my 8n is leaking oil should i just replace the seal in it or replace the hole the governor or get a repair kit and do the seal its dripping from the bottom dont no exactly were
   / Ford8n Antifreeze #100
WOW, i thought my spelling was bad as well as puntuation!!!
Just pointing it out as folks point out mine!!
"hole" instead of whole
"no" instead of Know
This just makes comprehension a bit difficult as you read is all, with the incorrect words.
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
