Ford8n Antifreeze
   / Ford8n Antifreeze
any good places to get parts at?
   / Ford8n Antifreeze #72
plenty.. what parts?
   / Ford8n Antifreeze
just normal stuff if i would need like water pump generator distributor things like that what i really need is a sediment bowl for her but i need to find out which one to get for it hard to tell over the internet pictures
   / Ford8n Antifreeze
each break leaks a lil bit of gear oil it is very low on gear oil in the rear end would it be wise to just fill it up and go with the leak or try and fix it i cant find replacement parts for breaks anywere
   / Ford8n Antifreeze
what i belive i need is the leather seal or neoprene seal im guessin it has a bad seal and is just leaking from that
   / Ford8n Antifreeze #76
every ford parts palce I know sells N and 00 series brake parts.. dealer.. just 8ns.. and 5000 other places online..
ditto on water pump.. ytmag is a great place to get parts.. electrical parts too.
if brakes leak.. then it needs axle seals and or hubs usually.
only one sediment bowl valve for an 8n really...
   / Ford8n Antifreeze #77
every ford parts place I know sells N and 00 series brake parts.. dealer.. just 8ns.. and 5000 other places online..
   / Ford8n Antifreeze #79
every now and then I make a post and for some reason the board hiccups and asks me if I want to leave the page.. if I say yes.. i get a dbl post. if I say no.. no post :(
   / Ford8n Antifreeze #80
Lots of folks seem to be having that problem, and I myself had it the other day.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
2016 Ford Explorer...
Cat TH407C Telehandler (A52748)
Cat TH407C...
