Mowing ENGINE RPM's on BX2660 for Running Woods Rotary Cutter
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #11
I have a bx2360 and I thought pto speed was at full throttle.
I don't have my manual handy, but there is a chart in it that shows the RPM for front and rear PTO which is pretty close. Our BX2200 didn't have a tach, so it was always full throttle. Like I mentioned earlier, you develop a feel after a while.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #12
I checked my manual the 1860 and 2360 share the same manual but I would assume all of the newer bx's are the same. Rear PTO 540 @ 3142 Mid 2500 @ 3043 I found it on specifications page 3.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #13
Yep, I just checked and it's the same on our 2660.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #15
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #16
TripleR said:
That is all it says on the cover; no mention of the other models.
I wonder why the 1860 and 2360 share the same manual instead of the 2360 and 2660?
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #17
That would seem to make more sense as the 2360 and 2660 seem to be closer to the same.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #18
lumberdink use use that much rpm s for fel work i keep mine at an idle wow that way i use a gallon in bout 2-2.5 hrs
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #19
With what tractor?
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2009 Wilson Commander Hopper Bottom (A59814)
2009 Wilson...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
