Mowing ENGINE RPM's on BX2660 for Running Woods Rotary Cutter
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #11
I have a bx2360 and I thought pto speed was at full throttle.
I don't have my manual handy, but there is a chart in it that shows the RPM for front and rear PTO which is pretty close. Our BX2200 didn't have a tach, so it was always full throttle. Like I mentioned earlier, you develop a feel after a while.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #12
I checked my manual the 1860 and 2360 share the same manual but I would assume all of the newer bx's are the same. Rear PTO 540 @ 3142 Mid 2500 @ 3043 I found it on specifications page 3.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #13
Yep, I just checked and it's the same on our 2660.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #15
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #16
TripleR said:
That is all it says on the cover; no mention of the other models.
I wonder why the 1860 and 2360 share the same manual instead of the 2360 and 2660?
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #17
That would seem to make more sense as the 2360 and 2660 seem to be closer to the same.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #18
lumberdink use use that much rpm s for fel work i keep mine at an idle wow that way i use a gallon in bout 2-2.5 hrs
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #19
With what tractor?
2014 Walker Compactor (A55787)
2014 Walker...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLANCH...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
UNUSED FUTURE 12" HYD MINI AUGER (A58376)
UNUSED FUTURE 12"...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
