Mowing ENGINE RPM's on BX2660 for Running Woods Rotary Cutter
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #11
I have a bx2360 and I thought pto speed was at full throttle.
I don't have my manual handy, but there is a chart in it that shows the RPM for front and rear PTO which is pretty close. Our BX2200 didn't have a tach, so it was always full throttle. Like I mentioned earlier, you develop a feel after a while.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #12
I checked my manual the 1860 and 2360 share the same manual but I would assume all of the newer bx's are the same. Rear PTO 540 @ 3142 Mid 2500 @ 3043 I found it on specifications page 3.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #13
Yep, I just checked and it's the same on our 2660.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #15
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #16
TripleR said:
That is all it says on the cover; no mention of the other models.
I wonder why the 1860 and 2360 share the same manual instead of the 2360 and 2660?
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #17
That would seem to make more sense as the 2360 and 2660 seem to be closer to the same.
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #18
lumberdink use use that much rpm s for fel work i keep mine at an idle wow that way i use a gallon in bout 2-2.5 hrs
   / ENGINE RPM's on BX2660 for Running Woods Rotary Cutter #19
With what tractor?
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A58375)
2012 FORD F-350 XL...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
