When to split Oak
   / When to split Oak
I have an Alaskan chain saw mill, and I hate to see the stuff going into a wood stove, to much fir and alder around here to burn a good hardwood like oak. But sawing, or splitting wet is better than dry. It can turn into a "rock".
Yes, I agree. Not being a sawyer, but it looked like this tree might have had some nice boards in it. It was taken down by an arborist for a friend of mine because he didn't like the leaves in his yard. Kind of sad to think it lived that long then to be taken down because of the leaves. All i have here are fir needles, would love to collect oak leaves for the garden. Out of curiosity, how small a piece can be slabbed on your saw mill?
   / When to split Oak #12
We burn as much oak as we can, and then we try to cut other hardwoods, because they burn longer, produce more BTU's at around 36.6 million BTU's per cord, compared to Pine, that burns at around 19.6 million BTU's per cord. When it is dry, it weighs in at about 1800lbs heavier than Pine per cord. It really is a great hardwood to burn, if it is well seasoned, but it does have that sour smell, like others have said here.
Do you have much of an issue with creosote burning pine, and firs? We use to live in Idaho, and Washington, and I know what you mean when you say that you have all fir trees. It was pretty rare to find good hardwoods in the mountains..
   / When to split Oak #14
split it asap, I have cut dead standing oak trees that had been dead for a long time and had no bark left on them and they were still wet as ****, oak takes awhile to dry, and when you throw it in your house you can't mistake the smell of it, has a sour smell.
I guess it what you are raised on I love the smell of fresh split oak
I too love the smell of oak.
But I got to wonder blucoondawg?? are you possibly mistaken that fowl smelling stuff for elm??
Cause it DOES smell. And rarely do I see an oak standing without bark. But it is extremely common with elm.
   / When to split Oak #15
I depends on the type of oak. White oak trees will rot if left standing, I guess they keep moisture inside. However, if you cut and season it, the wood will harden nicely. Live oak is totally different. Like others have said it will season into rock hard wood but even if you leave it standing, it will loose the bark over time and still remain standing. And that standing wood seasons into the same rock hard wood. Post oak is somewhere in the middle.
A local lake I go to still has some standing live oak in the shallow water areas after almost 50 years. All the other trees have rotted and falen but the major limbs of the live oak are still standing strong.
   / When to split Oak #16
while your cutting it up go ahead an splitt it as itll speed up the drying time.remember dry wood burns best.the oak will make a nice hot fire an put out the heat.we have no telling how meny cords of oak to cut up an split.
   / When to split Oak
Cqaigy, any thing under 3 ft gets hard to secure. And anything over 8 1/2 feet is to hard for me to handle.
That's kind of what i was thinking on the small end. Don't know if I'll see anymore oak but if i see anything that looks as straight as this stuff did, i'll be sure to get some advice from you before chopping it up into little pieces. :)
I don't have anything to compare to but i do clean the stove pipe every year. I get about a cup full of creosote, maybe a little less, on 20 feet of pipe.
   / When to split Oak #20
If you want to burn oak next winter (2013-14), it should be split and drying already. If the maul bounces back at you, it's elm :laughing:
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1996 LUFKIN 45' X 96' SPRING RIDE EXTENDABLE (A59575)
1996 LUFKIN 45' X...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
208316 (A58375)
208316 (A58375)
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
