Upgrading stereo and speakers on 5085M deluxe cab
/ Upgrading stereo and speakers on 5085M deluxe cab #1
pclausen
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
I'm having my cab frame replaced due to an incident that involved my GN trailer. I'm doing a lot of the labor myself, and I figured this would be a perfect opportunity to upgrade the stereo and speakers.
Here's a shot of the cab after removing the headliner:
Closeup showing the stereo connectors. The colorful one is for the Bluetooth mike (red arrow) and aux connector (yellow arrow). The black connector is for power and speakers. And then there is the antenna connector.
Here are some shots of the OEM 4x6 speakers:
Nothing to write home about for sure!
Here's where the right speaker is locate above the radio. The red arrow points to one of the mounting holes for the speaker.
Close up. The sound is almost 100% obscured by the radio!
The left speaker location is much better, but the sound still has to penetrate the headliner.
I should be able to plug the OEM mic into the female plug on the new stereo head unit, and I will also run a USB cable down to the right console so that I can connect my ipod via USB instead of the analog aux connection. This is the cable I plan to use which should make for a very OEM look. I plan to drill a whole, or use an existing hole for a flush mount.
Here's the radio I picked up:
I'm still trying to decide which 4x6 speakers to go with or perhaps pick up 6.5" speakers and use 4x6 to 6.5 adapters like these:
Well, that's pretty much it for now until I get tractor back from the shop with a new cab frame on it. Hopefully that will be by the end of next week!
/ Upgrading stereo and speakers on 5085M deluxe cab #2
Looking foreward to how this works out as I am thinking of upgrading the speakers on my E. I think mine only has one.
/ Upgrading stereo and speakers on 5085M deluxe cab #3
Great pictures and explaination. Look forward to updates as things progress.
/ Upgrading stereo and speakers on 5085M deluxe cab #4
I would go with 6.5" speakers as I have never heard a 4x6 that sounded very impressive at all.
I got my technical service/reference manuals for the 5085M Friday. They contain a wealth of info. For the radio connectors, things are very straight forward.
And yes, that WV adapter is the right one to mate with the X08 connector.
A shot of the wiring directly connected to the radio connector:
Interestingly, the X08 connector does not contain a ground. The ground is via the antenna plug (look at the 2nd picture I posted in the thread). I'll likely go ahead and wire the ground from the new radio through that X08 connector, likely using that spare switched power on pin 6.
Based on my measurements, that will be an extremely tight fit on the right side (where the radio is). The adapters shown above only work with speakers with a cutout of 5 1/8" or less.
I picked up these from Crutchfield yesterday to start with. They threw in the correct speaker adapters, so I don't need to do any cutting/soldering with the existing JD harness.
Kicker DS46 4" x 6" 2-way car speakers at Crutchfield.com
They are inexpensive at $49.99 for the pair, but the reviews looks promising, and when compared to the factory speakers side by side, they appear very well constructed. Much bigger magnets, beefier cage, etc. Crutchfield gives you 60 days to try them out and return/upgrade if things don't work out. Not bad. I'm going to run a remote turn in wire and sub line level outs before putting the interior of the cab back together. This was I can easily add a powered sub if needed without having to tear everything out again. I think I got room to the left of the seat.
/ Upgrading stereo and speakers on 5085M deluxe cab #7
Keep us posted and teh pictures comming. I enjoy following your post. It does seem a bit complecated. How difficult was it to remove the cab top. Look forward to getting your comments on the improvement of the sound quality.
Cheers
/ Upgrading stereo and speakers on 5085M deluxe cab #8
You might consider checking out the threads here about tinnitus when you get bored. That cab is close quarters, the tractor is probably fairly loud so the volume would have to turned up to get the full fidelity effect and that's where long term hearing damage can set in.
Sorry to put a damper on your project. Just saying be careful.
Speaking as one who has tinnitus from my days as an audio engineer.
Appreciate the heads up Dennis. Those oem speakers just doesn't do it for me and I find them causing me to get fatigued if I try to listen to music at a level where I can hear the performance. My hope is actually that I'll be able to listen at a lower volume and yet have a more fuller enjoyable experience. We'll see how it works out. I do realize this is a tractor, but I do love my music too.
Here's a couple of shots showing the oem vs. the $50 pair of kickers:
Made a little progress this weekend. Cut a hole in one of the caps on the right console for the USB connector:
Installed look:
/ Upgrading stereo and speakers on 5085M deluxe cab #11
How is the project going. Any updates.
Cheers.
Thanks for asking. Not much progress since I'm still waiting for the new cab frame to come in. Hopefully sometime this week.
I did get the wiring harness from the radio soldered and heat shrinked to the adapter that will plug into the tractor harness.
The black wire off to the right is ground, which will be connected directly to the ground nut on the cab frame since no ground is present in the factory harness. The little dark blue wire with the white stripe is the remote amp turn on that I'll extend down to behind the seat in case I feel the urge to add a 6.5" bazooka later. I'll extend sub line level out to the same location.
/ Upgrading stereo and speakers on 5085M deluxe cab #13
Theres also a speaker on the left hand side, opposite from the radio. I hear it better than the right one.
Totally agree. The right side speaker is mostly blocked by the radio and it's housing.
I'm toying with the idea of installing tweeters in the upper corners of the windshield to complement midrange drivers in the OEM location, followed by a sub mounted between the seat and left console, but then I remind myself, this is a tractor...
Then again, there is NO sound-stage the way Deere set this up!
/ Upgrading stereo and speakers on 5085M deluxe cab #16
I totally did not see you post about the left hand one, my bad. :confused3:
/ Upgrading stereo and speakers on 5085M deluxe cab #17
I am also adding an amplified 8in. sub behind the seat. I had to go with FUSION audio,will try it out and see what it sounds like,600watts:D
/ Upgrading stereo and speakers on 5085M deluxe cab #18
Your alternator will be screaming. ;) Better be water proof, or I shall pay you a visit with your garden hose. :laughing: The woofer that is.
/ Upgrading stereo and speakers on 5085M deluxe cab #19
geez JD, couldn't you supply something better than a no name Chinese paper cone speaker? Glad to see the replacement built with better materials. Today's electronics are so good most of the difference we hear is due to the speakers, and am glad you put a small subwoofer in so as not to overdrive the other relatively small speakers. Now if you want the best sound, super inexpensively, use a set of decent quality headphones, but then there's always the issue of not hearing things you really do want to hear...like a grinding or squealing noise from some mechanical problem. I have a Kubota L5740 cab on order, and I figured I would have to replace the speakers just like you did.
Crutchfield is really a gold mine here for info; I trust them totally. Drew
Got the aftermarket speakers installed.
Right side (above/behind the radio):
Left side:
Now that I finally have my tractor back from the shop, I should get this stereo upgrade completed over the next few days as I finish putting the interior back together.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
