When to split Oak
   / When to split Oak #31
I'm sure that is correct but pine will put out heat for a short time while Osage and Oak (especially Live Oak) will put out the heat for a longer period.
You might be interested to know that Pinion Pine (we have a lot of it around here) is 33.50 Million BTU's per cord, Osage Orange 32.90 and red or white oak 26.36, according to my third edition Pocket Reference. I was suprised.
   / When to split Oak #32
In my area the wood of choice is Larch/tamarack it is a softwood that looses its needles, this time of year they are yellow. The best ones are standing dead, right now I am burning fir, not as good but it was close and easy to get.
   / When to split Oak #33
Got some newly cut oak from a friend. Living in PNW one rarely cuts or burns anything but pine or fir so this oak is a novelty to me. I've been bucking it up and it seems to cut ok while green but im wondering about when it is drier. There are a bunch of smaller pieces i wont need to split but some of the larger pieces are between 24-30 ish across so they will need to be split. Does this stuff split easier after dry or when still green?
You can split this at any time. Oak rounds will harden up if ends are exposed after awhile but cutting off a half inch to an inch or so will give you a fresh surface with more moisture making it easier to split. Oak splits easier with a higher moisture content on its splitting surface. Capillaries on end wood close up and compress when they lose moisture giving the "rock hard" impression. That is why shearing off this layer makes it easier to split if you need it to sit around for awhile but the advantage of oak doing this is why dried red and white oak make such durable flooring.
   / When to split Oak
Thanks too for the heads up!
   / When to split Oak #35
Sweep's Library - Firewood BTU Comparison Charts has the btus of most wood species.
Common Name Species Name Pounds
/Cord MBTU
/Cord
Osage Orange (Hedge) Maclura pomifera 4,845 30.0
Hop Hornbeam (Ironwood) Ostrya virginiana 4,250 26.4
Persimmon, American Diospyros virginiana 4,165 25.8
Hickory, Shagbark Carya ovata 4,080 25.3
Dogwood, Pacific Cornus nuttallii 3,995 24.8
Holly, American Ilex Opaca 3,995 24.8
Birch, Black Betula lenta 3,910 24.2
Oak, White Quercus alba 3,910 24.2
Madrone, Pacific (Arbutus) Arbutus menziesii 3,825 23.7
Oak, Post Quercus stellata 3,825 23.7
are the top ten
   / When to split Oak #36
/Cord MBTU
/Cord
are the top ten
Another way of looking at it, generally, all species of wood have about the same btu's per pound when dry. The heavier the wood when dry, the more btu's it has.
Red oak will stay sound and split-able for at least three years if stored in logs off the ground. It doesn't really begin to dry out and season until it is split.
   / When to split Oak #37
C
Splitting large rounds as you describe always goes easier if you chainsaw your split line first. My rounds are about 18 to 21 " high. If over 20" or more across as you describe yours are, I chainsaw about half way down my split line into the round, take my 12 lb mall and split it in one shot.(maybe two or three if I keep missing the chainsaw cut line). I then cut the halves the same way and split these. Makes a 30" rouund much more manageable if you do not have a gas powered spitter and even if you do, you can lift the quarter pieces to the beam on a horizontal splitter way more easily. Of course if you have a vertical splitter, you wouldn't be doing any of this.
   / When to split Oak #38
C
I split my rounds down to iftable sizes with steel wedges and 10lb sledgehammer. I only saw apart knots and crotches. Much fast to wedge a round apart than to saw it half way. Been heating with wood since 76 burning 6 cord/yr and selling up to 6 or 8.
Got somewhee north of 50 cords Black Locust in the stacks (includes about 10 cords still to split/stactk). That is my "retirement" wood - the Locust Borer killed B. Locust all over the county the past several years and I harvested every tree I could get permission to.
Harry K
   / When to split Oak
I've started splitting the oak in between cutting up a bunch of fir limbs from last winters ice storm. I found, as mentioned in previous posts, that i can work from the edge of the rounds, essentially working around the the peripheral at about a 1/3 of the way in and get it split. The first split takes about 4 or more strikes with my splitting axe, but after that first piece is split out, 1 to 2 hits seems to work. I have to swing much harder then usual for fir or pine, i can really feel it in the palms of my hands.
   / When to split Oak #40
Have you tried a splitting maul rather than an axe? I have a 8 lb maul with a plastic handle that works pretty good. Also, you can make your splitting easier by cutting short pieces where there are knots, etc. some like their wood all the same length, I like to save the splitting work. Anything really ugly goes on the outdoor fire pit pile, life is too short.
Gang Reel Mower Attachment (A59228)
Gang Reel Mower...
International S1900 (A56438)
International...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
