Best steel for manure fork tines?
   / Best steel for manure fork tines? #1
lynrob
Member
Mid-Willamette Valley Oregon
Kubota L4740, MF65, Gehl 4610
I've been looking around for a manure fork for my tractor and skid steer. They seem expensive for what they are so I'm thinking about building one myself. (or maybe I'll discover why they cost so much :)) The frame seems straight forward but I'm not sure what to use for the tines. The commercial ones say they are made of spring steel or axle steel and are generally inch and a quarter to inch and a half in diameter.
Can any of you guys tell me what grade of steel would be best for this use? It seems to me that I would need something strong, tough and abrasion resistant with the ability to spring back if bent slightly. I know very little about the various types of steel other than the mild steel I've used for welding projects. I've been googling trying to educate myself but, so far, I haven't found much useful info.
   / Best steel for manure fork tines? #2
i would use the big round bale forks, my local steel supplier has a bunch of them. I am sure they are scrap price. Also your local ag dealer may have them with the sleve they slide in to. Usually they are cheap.
   / Best steel for manure fork tines? #3
just go to a wrecking yard and pick up used axles like I did. Weld them on and you're good to go. I got ones from half ton pickups and also use axles for hay prongs for round bales.
   / Best steel for manure fork tines? #4
thats the way i would go too ..and will last as long as any
   / Best steel for manure fork tines? #5
Yep, used axles is going to be the cheapest route.
If you insist on buying steel, axles are usually 4140. Which is about double the strength as plain mild steel.
   / Best steel for manure fork tines? #7
I bought one from a dealer years ago that was made of mild steel, trust me it did not work.:duh:
   / Best steel for manure fork tines? #8
Several years ago, I owned a job shop that manufactured the "spear" used to lift and rotate the round bales so that they could be wrapped with plastic. Those were all made from 4140 pre heat treated steel bars. Unfortunately, that are alloy is not readily weldable.
   / Best steel for manure fork tines? #10
i bought 9 tines off a wholesaler for 12.50 euro each. Its not worth your time to collect torsion bars or halfshafts and see them break at the welds after a couple of hours.
bad boy zero turn 72 (A56859)
bad boy zero turn...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2014 F-150 STX (A56438)
2014 F-150 STX...
BOX BLADE (A58214)
BOX BLADE (A58214)
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
