How to get gravel out of pipe?
   / How to get gravel out of pipe? #32
shop vac would be my first choice but water blasting could work as well.
1/2" copper pipe attached to garden hose and plung and lift with highest water pressure you can get out of a garden hose may "float" blast enough out??
   / How to get gravel out of pipe? #34
Hello,
I would use a Carpenters Brace with a Auger Bit that fits inside the pipe. Cleans it out quickly!!
Joe
   / How to get gravel out of pipe? #35
Tractor>inverter>shop vac>empty pipe>empty vac into FEL>dump FEL at point of your choosing>all done!!:tractor:
   / How to get gravel out of pipe? #36
Don't forget Pilot,, if the shop vac doesn't take care of the problem,, I can still come up with some type of explosive device with the use of a tractor front end loader as a shield,, if needed.. just let me know.. Lou
Unfortunately thats always been the preferred method her in Michigan.
Pipe+Powder+Rocks=somethings moving fast
We have had our share of bomb nuts her in Michigan.
Timmothy McVeigh practiced on a farm here in Deckerville.
Not sure we will ever recover from that nut.
Stick to the bubble gum or shop vac
   / How to get gravel out of pipe? #37
If the pipe is PVC (which I doubt it is in this case) muriatic, sulferic, or hydrocloric acid makes things disappear.
   / How to get gravel out of pipe? #38
Take a masonry bit a tad smaller than the inside diameter of the pipe and a hammer drill and all will be well in a few minutes. I know this because I used to work at an airport with gravel T-hanger floors.
   / How to get gravel out of pipe? #39
I'm with you on the water blast; only problem, working with a 3/4" pipe means you would have to fashion the 1/2" copper pipe, but it should work well. As I recall, this technique is used to recover sulfur...they pump steam down a pipe that's inside another larger pipe, and the product comes up the space between. Of course air should work too.
Water sound like a good idea, but there is no nearby source of water.
After this storm passes thru and I can open one of the doors to the hangar without it blowing off the hinges, I intend to duct tape a small pipe to my shop vac so I can slip it into the pipe in the ground and suck the rest out.
Thanks for all the suggestions.
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
207280 (A52708)
207280 (A52708)
