How to get gravel out of pipe?
   / How to get gravel out of pipe? #32
shop vac would be my first choice but water blasting could work as well.
1/2" copper pipe attached to garden hose and plung and lift with highest water pressure you can get out of a garden hose may "float" blast enough out??
   / How to get gravel out of pipe? #34
Hello,
I would use a Carpenters Brace with a Auger Bit that fits inside the pipe. Cleans it out quickly!!
Joe
   / How to get gravel out of pipe? #35
Tractor>inverter>shop vac>empty pipe>empty vac into FEL>dump FEL at point of your choosing>all done!!:tractor:
   / How to get gravel out of pipe? #36
Don't forget Pilot,, if the shop vac doesn't take care of the problem,, I can still come up with some type of explosive device with the use of a tractor front end loader as a shield,, if needed.. just let me know.. Lou
Unfortunately thats always been the preferred method her in Michigan.
Pipe+Powder+Rocks=somethings moving fast
We have had our share of bomb nuts her in Michigan.
Timmothy McVeigh practiced on a farm here in Deckerville.
Not sure we will ever recover from that nut.
Stick to the bubble gum or shop vac
   / How to get gravel out of pipe? #37
If the pipe is PVC (which I doubt it is in this case) muriatic, sulferic, or hydrocloric acid makes things disappear.
   / How to get gravel out of pipe? #38
Take a masonry bit a tad smaller than the inside diameter of the pipe and a hammer drill and all will be well in a few minutes. I know this because I used to work at an airport with gravel T-hanger floors.
   / How to get gravel out of pipe? #39
I'm with you on the water blast; only problem, working with a 3/4" pipe means you would have to fashion the 1/2" copper pipe, but it should work well. As I recall, this technique is used to recover sulfur...they pump steam down a pipe that's inside another larger pipe, and the product comes up the space between. Of course air should work too.
Water sound like a good idea, but there is no nearby source of water.
After this storm passes thru and I can open one of the doors to the hangar without it blowing off the hinges, I intend to duct tape a small pipe to my shop vac so I can slip it into the pipe in the ground and suck the rest out.
Thanks for all the suggestions.
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A59231)
2025 Nationcraft...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
