ATV Snowplow?
   / ATV Snowplow? #1
RobA
Chester County, SE PA
Kubota L5030 HST
Does anyone have a snowplow on their ATV? Recommendations?
I have a plow for my tractor but thought about an ATV snowplow for lighter snowfalls and tighter spaces.
   / ATV Snowplow? #2
This is what I use and it works great. Grizzly with a Rhino snow plow. Just plowed after an 8" snowfall with no problem. Easy, fast, and doesn't hurt the blacktop drive.
   / ATV Snowplow? #3
An ATV with a plow is an excellent choice for getting rid of light to moderate snowfalls up to 8 inches or so. It is also a lot of fun............
   / ATV Snowplow? #4
You may want to look at "Moose" plows also.I have had a ATV with a plow for 15 years.They have their place for sure.
   / ATV Snowplow?
Hand lift? Electric lift? Winch lift? (I do not currently have a winch on my ATV)
   / ATV Snowplow? #6
We have two set-up,a Kawasaki Praire 400 with a manual lift and a Yamaha Grizzley with a winch.......I prefer the manual myself.
   / ATV Snowplow? #7
ATV plows can do the job well. It's been my primary method of snow removal for my parent's place for many years. Old Suzuki LT4WD. Plow was a manual lift until I rigged an actuator to lift it. Works pretty well until the snow is either too deep or hard packed.
   / ATV Snowplow? #8
I had a manual lift on my previous atv. It was a bit awkward to use but I got used to it. The winch I have now is much easier but you have to be careful. There is no limiter to shut off the winch when the blade gets to full up travel.
   / ATV Snowplow? #9
I had a Swisher plow on my Traxter -- it was ok for clearing in front of the garage but not great for the long laneway (1/4 mile plus). unit "clipped" on to a frame mount that I left on all the time. Raised and lowered by winch. In comparison to a three point blade or blower -- well there just isn't a comparison. Sold the blade and mount this year after not using it for a couple of winters. Oh yeah -- had to weld new brackets on the blade -- sheared them off in short order on the long driveway plow. Also had to buy chains to get enough omphh to push any kind of snow.
   / ATV Snowplow? #10
I have a Cycle Country snow plow on my Yamaha Rhino. I plow a 2.5 mile road/driveway with it at times. other deeper snow I use my Kubota MX5100. I eventually wore out the mounting holes on the blade itself. Mostly from excessive use. So, I called Cycle Country to try and order just the plow, no push tubes or plow frame.
I explained the problem and they took my address and simply sent me a whole new plow (with the frame!) at no charge. i was fully willing to pay for the part since i was the one that wore it out but they didn't hesitate to send it for free.
   / ATV Snowplow? #11
I also have a Cycle Country plow on my early-90s vintage Polaris 350. Works well for light snow up to 6" or so. Manual lift doesn't lift quite as high as I'd like, tried using a winch but it only lasted one season so I'm back to the manual. I welded a ring a bit further forward on the plow frame than the original one where the lift chain connects, and that helps.
Pins that hold the plow arms to the ATV frame don't seem to stay in for some reason...I've experimented with different types, but they all seem to come loose after a while. Pretty easy to replace, but still kind of a PITA lying in the snow changing them.
For anything deeper, or wet snow I use the tractor w/FEL.
   / ATV Snowplow? #12
I have a Polaris Glacier 3 plow on my Sportsman 400HO, it will handle a foot no problems. Have had 6" snowfall, then 4", no problems at all. The blade mounts at the front and mid point, plenty of strength, mount bolts on in 5 spots.
   / ATV Snowplow? #13
Anyone out there use an RTV for snow plowing on a steep paved driveway? I would like to try it but I am concerned mainly about traction. Right now I use a B7800 with a rear blade that I angle manually and if the snow is less than 5-6 inches I can zoom down the drive and quickly clear it off in 2 or 3 passes. With more snow I find the landscape blade does not have enough height to be very effective and then I have to use the FEL to move the snow to the side while trying not to fall into the ravine. I found that the paved drive can ice over a lot quicker than when it was gravel, if I travel up and down don't have it cleaned down to pavement. I did not have my chains on the tractor last night and got seriously stuck down at the bottom for the first time ever. The blade floated up a little on the pass down the hill and left a thin layer of snow and once this was driven on, it turned right into ice. Needless to say, the chains are going on TODAY. But I own an RTV 900 that works pretty well to get around in the snow, so I could get a plow for it, if I knew that it would work to remove deeper snow faster than the tractor without getting stuck. Any thoughts?
Frank
   / ATV Snowplow? #14
I also use a Cycle Country blade with a winch. It was my main snow tool 5 years ago when we moved into our new home on the mountain. After back to back years of record breaking snowfalls I went to a tractor and 3pt snow blower. I still use the ATV for light snows and clean up. Be careful with a winch I snapped the cable multiple times lifting the blade too high. You get to be good at cutting and re-attaching the cable. 50 feet of cable gets bound up after plowing for awhile and kinks then you break it when you lift too high. I shortened the cable to about 6-8 feet and it doesn't bind and snap.
Also if you have a gravel driveway using a piece of ABS or PVC pipe over the cutting edge saves gravel untill the ground freezes up good and you have a packed base to plow on. My cutting edge is 1 1/2" wide and a 2" piece of pipe fits right over the edge. Just run it through a table saw to open it up down the center and slide it on.
   / ATV Snowplow? #15
A neighbor has a front mounted gas powered snowblower for his ATV, I cant recall who makes this , all I know is its made to fit ATVs. It is definitely more costly than a blade but it works wonder and has no real limitations. We just had a storm dumping 45 cm (17-20 inches?) and he cleared his own driveway and 2 or 3 other neigbors in quick time and did a swell job of it.
   / ATV Snowplow? #16
I have a Cycle Country blade also. I lift it with a winch. I wore out the steel aircraft cable on my winch pretty quickly and replaced it with Amsteel Blue synthetic winch rope. It wears a lot better than the steel cable and doesn't get tangled up like the steel cable.
   / ATV Snowplow? #17
I plan on doig the same come spring. Will kerp the cable for a spare.
   / ATV Snowplow? #18
Sand and salt -- once a surface turns to ice or has ice underneath it is pretty easy to go where you don't want to or lose traction on driving wheels. For the price of a blade and setup on the RTV you can probably find a blower or wider blade for the tractor and a set of chains. I know lots of folks that use ATV's and RTV's to clear snow but four wheel drive tractors with three points and hydraulics are tough to beat for both speed and not getting stuck -JMHO
   / ATV Snowplow? #19
I had a 50 inch Cycle Country plow on a 600 Polaris Sportsman which was a good plow. I now have a 54 inch Eagle plow on my 850 Sportsman and that plow is beast. Ordered the Eagle plow from promarkoffroad for $400 shipped free to my house. I'm impressed with the Eagle plow.
   / ATV Snowplow? #20
If had a choice between using an RTV with plow versus my grader blade, I'd take the RTV. Some of my displeasure with the rear mounted blade could be alleviated with chains (sliding sideways). But for me at least, I find it far easier to control what I'm plowing with the blade in front than when I'm pulling a blade. Which is why I usually use the ATV with plow. It's old and smaller, but I don't do damage with it either.
John Deere 4600 (A53317)
John Deere 4600...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
