Bought Ford 777F FEL and it is leaking down rapidly
/ Bought Ford 777F FEL and it is leaking down rapidly #1
Browning12
murfreesboro, TN
65 Ford 5000
Have older Ford 5000 (65), added a 777F FEL, using Factory Control valve (2-spool, with detents) the top lever will raise/lower loader and bucket using the current setup (on/off valve on loader that shifts fluid from one system to the other). Want to add control valve and see if this fixes my issue. Issue is both systems leak down rapidly. Also, will not pick up full bucket of gravel. I've fully extended FEL and added fluid to get it up to correct levels, was about 4gal low! I've also toyed with the rear switch to get both systems working concurrently and pulled out the black knob, (according to owners manual). Bought a Chief CV at TSC, double spool, open , but it seems too big. It weighs 25lbs!! Will it be OK to downsize this control valve to one that is double spool open and weighs about 12 lbs? Also, if I need to rebuild/repack the cylinders I'm assuming I need to disconnect the FEL. it appears it only has top pins, do you tie up the FEL and pull those pins (one on each side?) Thanks for any help!
/ Bought Ford 777F FEL and it is leaking down rapidly #2
If you matched the GPM of the valve to tractor pump flow you should be good.
What is the condition of your fluid? Clear , milky, etc?
Have you changed filters and cleaned screens if you have them?
Have you taken any pressure readings?
Have you heard the relief valves activating lately.
If you have installed the new valve and the lift arms still leak down, I would suspect the lift arm cyl for worn seals.
Have not installed the CV, wasnt sure I got the right one. fluid looks like oil should, just added alot of new fluid, I will get a hydraulic gauge and start testing , not sure how to identify the GPM of the tractor pump but if it is less than the CV will this have negative impact? Also , if the two hoses were hooked up backwards would this cause these symptoms?, I traced one coming out of the factory CV under seat and the one that said drop appeared to go through the original on/off valve all the way to the bottom of the cylinders.
Thanks for the direction, exactly what I needed, an idea where to go next, as you can prob tell this is my first tractor!
/ Bought Ford 777F FEL and it is leaking down rapidly #4
/ Bought Ford 777F FEL and it is leaking down rapidly #5
Make one of these. Cost about $30
OK it says Max Flow Rate 30GPM, according to tractor data the ford 5000 has a pump that flows 6gpm.
that is great thanks for the the link(s), 12 lbs sounds more like size I need, Ill take this 25lb CV back to TSC and order a smaller one, next step will be the cylinders, on the loader I have to unattach it appears to be two pins. does that sound correct? If I have to rebuild the one cylinder that has oil on arm the loader will definitely need to be unattached, I plan on chaining it up to tree limb
that looks just like the one I use to compression test my boat & chainsaw engines, you just get one for hydraulics and use same principle I see, where is best place to find one of those? , I only have Northern Tool and TSC nearby, maybe Farmers Co-op, or I guess online
/ Bought Ford 777F FEL and it is leaking down rapidly #10
Make sure to get a 3000 psi gage.
Surplus Center - 3000 PSI 2.5" LF LM GAUGE
Those stores you mention should have the parts.
Are you sure you have to un-attach the loader to remove the cyl.
the bottom of cylinder sits inside a square box which sits inside another square box housing. no access to the bottom of the cylinder, ill look for some pics, and it appears once you pull the pin from the top of the box the bottom would pull out as you back up the tractor. Kind of odd only 2pins would hold on the entire loader, but i guess weight of the loader would be pushing down all the time? The fact I can see oil on the silver part of the cylnder makes me think a seal is bad, also when I had bucket off the front cylinder would fall open, would gravity do this? I could understand if tractor wasnt running but it was running, so essentially both systems (large pickup) and small front bucket cylinders are leaking down while tractor is running. Loader sit couple years in field unused so im wondering if this caused them to go bad , have to get that gauge and see, do you screw the gauge into the hose that is going to each cylinder or just get a a connector and plug it in the quick connects on the tractor?
Thanks!
/ Bought Ford 777F FEL and it is leaking down rapidly #14
When you have the lack of lift strength and leak down I have learned to suspect the o ring that seals the piston to the push rod. Usually the piston is connected to the push rod by a large nut. The push rod will have a groove for a small o ring to seal to the inside bore of the piston. These o rings are about 1" in diameter. These o rings fail and then you have an internal leak which does not show up outside the cylinder. Don't buy a seal kit as they are often expensive and unless you have an external leak are often not needed. The small o ring can be found at a hydraulics shop for pennies.
o ring #18 in the photo is the one I am referring to. This is not the cylinder you have but is similar!
Dave M7040
I hope this is it, that is great advice, if it is only the O-ring I'll be in good shape, I really appreciate the direction, I will keep you posted
got the gauge, it appears on the lift hose, goes to 2250 , then drops to <500 immediately when I let off the lever, the drop side goes to 2250 then drops to 1500, holds for about a minute, any ideas if this is my issue (factory Control valve leaking down?) If this is the case when I get my new Control valve installed on the loader will I tie up the levers on the factory CV to always be applying LIFT?
Thanks!
/ Bought Ford 777F FEL and it is leaking down rapidly #17
Before replacing the control valve consider removing the hydraulic lines from the control valve to conduct a test.
Jack the bucket up a few inches then remove the hydraulic lines with a jack supporting the bucket. Cap the line on the lift side of the cylinder and leave the down line open. Add weight to the bucket and watch your pressure gauge and also for oil coming out down line as you lower the jack. Removing the jack will pressurize the cylinders. If you are loosing pressure with the bucket loaded and the control valve no longer in the circuit you have established the problem is an internal leak in the cylinder(s).
Dave M7040
/ Bought Ford 777F FEL and it is leaking down rapidly #18
If you install the new valve and the cyl is good, you should be able to activate the relief on the loader valve, and read the pressure.
The cyl, if good will hold the load up for a long time.
If the cyl is leaking, the relief probably will not operate.
If the cyl leaks down after installing the loader valve, then the other possible causes are o-ring on the rod nut on the cyl, or piston seals worn.
/ Bought Ford 777F FEL and it is leaking down rapidly #19
Thanks!
On a loader valve that is working correctly, you will not need to tie off anything, as the spools in neutral are supposed to hold the load for a while.
Most all loaders will drop over time. Some stay up days, weeks months, and others, you can watch them descend,
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
UNUSED ZJG ZJ-13 EXCAVATOR (A60430)
UNUSED ZJG ZJ-13...
2014 CATERPILLAR 930K WHEEL LOADER (A60429)
2014 CATERPILLAR...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2008 GENIE S-65 TELESCOPIC BOOM LIFT (A60429)
2008 GENIE S-65...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
