Have you ever seen the "indoor" type that Dave 1949 mentioned? I second his thoughts. As you prolly guess, I do have one. One big advantage is the amazing amount of heat that is wasted from an OWB. Now not wasted because it's a OWB, but because it's a OWB. What I mean is no matter how much insulation a OWB has, it's leaking (radiating) heat to the outdoors. My indoor boiler is well insulated, I'd assume as well as a OWB, and boy does that thing throw some heat. But it's in the house! Loading in your under pants is a big bonus and my wife fully participates in feeding it (because it's inside). I believe that all the new OWB's have to be or are "gassification" types, but not positive on that and I'v read of many happy Central boiler owners. May I suggest you visit
The Boiler Room - Wood Boilers and Furnaces | Hearth.com Forums Home and read up there. They tend to be snobbish for the indoor "gassers", but lots of OWB guys there too, they just keep quiet. As for dry wood, any and all wood burning appliance will greatly increase their efficiencies burning dry wood. The TON of so of water that is in each cord of green wood, is going to need to come out reguardless wether your boiler will burn it or not. Water does not burn & it takes heat to evaporate it. (btu's that should go for to your heat rather than drying green wood) Keep up with your reading so that you end up a fully satisfied, wave at the propane truck as it goes by, happy wood burner. (like me) Good luck.
