YM 2000, Looking at a very Clean Front End Loader, bad engine
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #1
toppop52
Super Star Member
Eastern Shore of Maryland
Massey Ferguson 1723, Cub Cadet 1864
I found a very clean and nice YM 2000 with 2TR20A engine, that has serious blow by and needs a long squirt of starter fluid to start. Seems fairly common with these. I talked to Hoye and they tell me $350 for refresh parts less pistons. The hydraulics and everything work great, nice seat, paint, steering wheel, nearly new tires. Transmission, clutch, brakes, diff and all seem very solid and the tractor will actually run fairly decent once started. It is supposedly an 80's model, it's red with a white stripe where the YANMAR is. It's 2wd. Asking price is $2100, might get him down a couple bills but he ain't going far. Is it worth a roll of the dice or no?
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #2
If it were me, I would do it. That's a couple thousand less than a clean tractor that doesn't need anything.
If ether has been used in it, the ring lands in the pistons are likely shattered. Rings likewise. So budget some money to repair that.
And - before overhauling the engine I would try the cheapskate approach. Look for my posts in this thread. I installed a direct-replacement much stronger starter from a larger Yanmar which cranks so vigorously that I think it would start any YM2000 regardless of condition. Once your rig starts reliably you might decide to just run heavy oil and put it in service as-is, particularly if you only need it a few hours per year.
We've read here several times: don't use ether in the small Yanmars!
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #3
most yanmars do NOT need ether and its not a common thing either!! Those are guys that are use to big diesel equiptment.
Also if its a ym2000 its a 78 or 79 they did not make them into the 80s.
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #4
If you can do the work it could be a good deal. If it has "serious" blow by I would plan on making repairs and keeping the old starter. :D
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #5
Yes, if you get it make the repairs.You will likely have much more power. Don't know the condition of the loader , New loader is 3-4K. IMO, It would be a good deal
The fairly common thing I meant was blow by, also saw a bunch of slow start issues. Of course you don't read about guys with perfect running tractors, they have no reason to post. LOL
I'm going to look again and make an offer, thanks for the help!
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #8
u can get those VN loaders for less than $2k so if that's what it is don't use the $3k figure.
   / YM 2000, Looking at a very Clean Front End Loader, bad engine #9
oh ok I got ya. I deal with loggers and those guys will run equipment on ether till it catches!!! Like when there starting an old diesel on a cold day they will run the engine on ether till the engine starts fireing on diesel. I have also seen when they change filter and take injectors out instead of bleeding the fuel they just run it on ether till it bleeds itself. Just spray some in there start it and then hold the ether down while it runs till all the air is bled!!!
This tractor is red with white stripe, I'll try to post a pic from my real computer in a fe minutes. What year was red? Anyone know?
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
MASSAGE CHAIR (A58214)
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
Ratchet Straps (A59230)
Ratchet Straps...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
