Smaller John Deere out pulls bigger Kubota
   / Smaller John Deere out pulls bigger Kubota #1
Carl Bert
Rockland county, New York
Kubota B26, John deere X595
I couldn't believe it. I have an 18' 2500 lb trailer, which I used to pick up a piece of furniture. When I got it home, I decided if I pulled the trailer up on my lawn to my front door it would make getting it inside much easier. We had just had about 6" of snow fall, there is maybe 3" left.
When I got home with the new hutch, I got out my X595, hooked it up to the trailer, and attempted to pull it up the approx. 30 degree, snow covered incline to my front door. The little John Deere pulled that 2500 lb trailer 3/4 of the way up the 75' long incline, and the wheels started to spin, so I stopped and backed down the hill. If I wasn't worried about damaging the lawn, it would have made it to the top.
I got out the Kubota B26, which I had no doubt would do it with no problem. I hooked it up and proceeded up the hill. Once the 4 wheels of the Kubota were off the driveway and on the snow it started to spin. There was no moving it, not even a foot. To say the least, I was shocked. I like digging with my Kubota, but nothing beats a John Deere for all around performance. Things like this, is what makes Deere worth the extra bucks. I just love my Deere
   / Smaller John Deere out pulls bigger Kubota #2
What does the JD have for tires.? Obviously the Kubota has industrial s which are next to useless in snow.
   / Smaller John Deere out pulls bigger Kubota #3
Haha, what a troll... :)
Lets guess which tractor has turfs and which has R4 industrial tires...
:rolleyes:
   / Smaller John Deere out pulls bigger Kubota #4
What a bunch of baloney!
   / Smaller John Deere out pulls bigger Kubota #5
i don't know but many years ago i had to pull start my dad's 4020 on a wet pasture and did it with a Deere 112 mower.:eek: The other 30hp tractor couldn't do it.
i also know that my 4520 needs to be in 4x4 to pull the x749 if the tranny is engaged on tight packed gravel. Found that out by accident as I had released the transmission drive and it slipped back in to the engaged position when i attempted to pull it backwards.
   / Smaller John Deere out pulls bigger Kubota #6
I'm not questioning the facts. Just saying it's baloney to turn it into a brand thing.
   / Smaller John Deere out pulls bigger Kubota #7
Yeah, tire style, weight, distribution, differential type, etc. make for traction. Not the brand of tractor turning the gears.
   / Smaller John Deere out pulls bigger Kubota #8
:rolleyes:
I think he was referring to small tractors using turfs on snow, those machines aren't heavy enough to make industrials "grip". Larger tractors including mine almost always use R4's on snow.
I fully realize what you stated is true. I just was very surprised, to say the least, and thought it was a story worth sharing.
   / Smaller John Deere out pulls bigger Kubota #10
Tractor characteristics made the difference.
Paint color gets the credit.
If the Deere & kubota were set up & equipped similarly, the results would be similar as well.
   / Smaller John Deere out pulls bigger Kubota #11
Oh come on that is one of the silliest, weakest comparisons I ever heard. This is not the first time either I don't believe, why don't you just sell the Kubota?
   / Smaller John Deere out pulls bigger Kubota #12
:thumbsup::thumbsup:
It's time to dump this thread.
   / Smaller John Deere out pulls bigger Kubota #13
D@mn, I thought this was the JD section of the forum.
   / Smaller John Deere out pulls bigger Kubota #16
Too many Bota lovers trolling in a JD section to blast a guy for praising his JD??
Truth is many of us don't even pay any attention to what forum in which we post, I just hit "Today's Posts" and go from there. We own Kubota, John Deere, Massey, Ferguson, Case, Ford and Kioti, so when I see one of those mentioned it piques my interest and I am likely to comment.
As I see it, it doesn't matter on which forum you post, if you are going to bash a tractor brand, be prepared to back it up.
   / Smaller John Deere out pulls bigger Kubota #18
Where was the bashing on the Op's post?
   / Smaller John Deere out pulls bigger Kubota #19
+1 I own a JD and a Kioti, and I do not play ANY attention to which forum I am in.
   / Smaller John Deere out pulls bigger Kubota #20
So a garden tractor out pulled a compact tractor. Truly amazing! They are either making the green paint out of some very dense material like lead or gold to aide in traction OR the green paint hasn't cured and the vapors are affecting the thought process of the owner. Here are pictures if the competitors.
WATER TRAILER (A58214)
CAT 289D3 (A58214)
CAT 289D3 (A58214)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
