Chipper Questions
   / Chipper Questions #1
2 Horse
MI
Kubota MX5000
Well it's just about that time of year. Need to pick up a 3 point chipper and don't know anything about them.
I have 44 pto hp tractor .so I'm thing I 'll have enough power for a good chipper.
Don't want to break the bank or buy crap. I'll need to chip branches under 4" and will be running about 20 hours a week.
What brand and size is best for my app. Would like to have HYD feeding if it not going to jack the price up to much.
What is working for you guy's ?
Thanks
   / Chipper Questions #2
Search engine is your friend I bought a Wallenstein BMX 42 chipper shredder and really didn't need hydro feed.
   / Chipper Questions #3
If your working it that much 52 weeks a year either get something like a Wallenstein BX42R or 3 of the Chinese clones (Jinma, WoodMax etc).
do a google search
chipper site:tractorbynet.com
   / Chipper Questions #5
I totally agree on the Bear Cat, but if you are going to do that much chipping you really need a model with a blower. Otherwise you spend all your time clearing the chips out from under it. I have a Bear Cat 4.5 inch model with blower that I no longer see on their site. It's similar to this one - may be the same thing just re-labeled to 5 inch, since mine clearly takes 5" material. I run it on a 29 hp JD 870 with no problems.
Terry
   / Chipper Questions #6
Look at Salsco. Well built and bulletproof.
   / Chipper Questions #8
I own a hydro feed Vermeer PTO 6" chipper. They're hard to come by but if you can find one they are will last you forever. It's built like a tank and weighs 1400lbs.
Model is a 606.
Do you have power beyond hydraulics?
I was looking for a used Wallenstein 62R (hydro) as my first choice. Reason I like that chipper is because it can take up to a 12" wide slab, even though its only 6" diameter capacity. I have a sawmill and this would be very helpful for my slabs, but I came across a deal on the Vermeer that I couldn't pass up and I'm glad I did. It's definitely the most "commercially" built PTO chipper I came across.
Do you mind me asking what you do that will require 20hrs a week of chipping? That sure is a lot, and with that much chipping, don't even consider one without hydro feed.
You have plenty of power for a 5" or 6" chipper so I wouldn't go less than that.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2015 Peterbilt National NBT40 40 Ton Straight Boom Crane Truck (A60460)
2015 Peterbilt...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2017 FORD F350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F350 XL...
