How do you repair a damaged Kubota cab top ?
   / How do you repair a damaged Kubota cab top ?
What is so special about the 4610 top? How huge is that thing? The plastic top for a B26 is "only" $500.
We picked up a damaged top for a larger tractor, today from our dealer. Did a google search on some numbers we found on it. Cost on it was less than 1100.00. We then checked the price from the same dealer on our L4610 top & was quoted 1581.00
I guess we just lucked out with expensive parts.
Thanks to all for your help.
We took the plunge today, after several test trials, & repaired it with common hot melt glue. Although we know it is not what we had hoped for, I think it will do the job. If by chance it fails, we will just cover the whole top.
Before doing the job we ran a test, gluing a small piece to the underside at a 90 deg position, let it cure for a day & could not pull it off with pliars. Finally cut it off short with a hack saw blade. This seemed to hold better than any of the plastic weld rods we tried.
   / How do you repair a damaged Kubota cab top ? #13
They are advertising FlexSeal pretty heavily. I suspect it is a gimmick though.
   / How do you repair a damaged Kubota cab top ? #14
That stuff is garbage from what I can tell through research a while back - no actual experience with it. There are definitely much more proven options available at places like HD.
   / How do you repair a damaged Kubota cab top ? #15
food for thought, use aluminum sheet held in place with pop-rivets and sealed with caulking compound. Orange paint would almost make it look OEM.
   / How do you repair a damaged Kubota cab top ? #16
How about a flexible roofing membrane. It is on every rv and seams to work out well. Drape it over the sides and run a band of aluminum flat bar to hold it in place.
   / How do you repair a damaged Kubota cab top ? #17
   / How do you repair a damaged Kubota cab top ? #18
Body shop
   / How do you repair a damaged Kubota cab top ? #19
I know this post is old, but anyone have a solution? Ripped the rear lights out of mine. Real PITA of a set up for the light brackets. Tried the 2 part plastic weld epoxy but it seems wonky.
   / How do you repair a damaged Kubota cab top ? #20
Most automotive parts places have the kit with a quart of liquid resin & catalyst along with fiberglass cloth. Has the brush as well. I have used a lot of this product on metal as well as fiberglass. Works fine and lasts forever. Paint it too.
Best Mike
KMC 5610 (A53084)
KMC 5610 (A53084)
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
