Picking a trailer for new JD 5083E
   / Picking a trailer for new JD 5083E #31
Yes, kind of. You really need to weigh it. Most 12k ttrailers are closer to 3k empty.
Chris
My 12k bri-mar deckover 8'x20' weighs 3700lbs empty according to the mfg website.
   / Picking a trailer for new JD 5083E #32
dstacy,
sounds like you already know the answer to that. The deck length has nothing to do with it. Its stopping the load. Everyone wants to talk about how much horsepower their rig has, but that's only for bragging. If someone pulled out in front of you, would you feel confident that you could stop the truck trailer and tractor in a hurry and not kill someone? I towed my 5083E with a 2005 3500 dodge SRW with a cummins and a 6 speed. Did I haul it everywhere I wanted, Yes. Did it pucker my *** during a panic stop, YOU BETTER BELIEVE IT. You can load it in such a way to keep the weight off the truck, but the brakes are the brakes. I wont tell you it can't be done, but I would suggest not doing it often.
   / Picking a trailer for new JD 5083E #33
dstacy,
Ok so would you be willing to educate me since I really don't know or understand.
My truck has the towing package from the factory and a port to plug in a brake controller. I thought if I plugged in a brake controller it would use the brakes on the trailer and I'd wouldn't have problems with stopping. I know a V-10 F250 can tow the weight.
Thanks in advance for the replies.
   / Picking a trailer for new JD 5083E #34
well yes, and no. I can get into the legal stuff but anyways. I would reccomend a bigger truck personally. yes the 7 pin connector will give you trailer brakes. However, when you brake hard, ALOT of weight gets transfered to the truck. I personally dont think a 3/4 ton is the smartest idea. Will it pull it? sure, will it grunt and groan? you better believe it. The only thing you would have going for you is if the tire is unballasted. I'm not really sure what your question is though?
   / Picking a trailer for new JD 5083E #36
Again this isn't a Deere, but here's a picture of how I load up with an M9540 and 15' shredder. I know I'm way overweight. I just take it nice and slow and prepare to stop way in advance.
As was already stated, I would definitely recommend a deck-over for that size tractor/loader - especially if you plan to haul an implement on the rear. Salem-20120922-00046.jpg
   / Picking a trailer for new JD 5083E #37
Love all these pics, you guys are hauling some serious Toys on those 14k trailers!!
Butterfly Artwork (A55758)
Butterfly Artwork...
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2025 Wolverine MAD-12-12D Auger Mini Skid Steer Attachment (A56857)
2025 Wolverine...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
3410 (A47477)
3410 (A47477)
