Pallet Fork Question
   / Pallet Fork Question #41
Yes I'll check them out also...........
   / Pallet Fork Question #42
I just checked these Artillian forks out---nice if you have a John Deere but I have a Kioti and need a pin style maybe with adujustable brackets that slide right to left to get my 40" I need. Would be nice to find a Quick attachment for the pin style. I see Kioti makes one for about $400 but not sure if it will work on mine.........
   / Pallet Fork Question #43
Nick, for your machine the Artillian Pin-On frame may work. The design has some flexibility in dimensions during manufacture. Finding out if it can be made to work would just require a few measurements from you. No expectations, just thought I'd mention it.
   / Pallet Fork Question #44
I have a set of frontier forks, they are welded tubes, not bent or solid. They cost $750 when we bought the tractor. I run extending boom forklifts all the time at work and I assure you floating forks are quite capable of dumping. They are better for un even loading situations, and can be chained down to prevent floating if needed. I don't believe that 300x loader will lift much over 1000 lbs, and by the looks you will never hurt those forks. I would buy them in a minute if I needed a set, only thing I see wrong is the looks. Of course I am a farmer and I put function over form.
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2008 CATERPILLAR 314CL CR EXCAVATOR (A51242)
2008 CATERPILLAR...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
