new X540 or 2006 used x720????
   / new X540 or 2006 used x720???? #1
jdman80
Marissa
2013 John Deere X540
I am dealing with my dealer on a new (different) lawnmower. I currently have a 2005 GX345 54in cut with 254hrs. My two options are a new X540 54in cut or a 2006 X720 62in cut with 265hrs no PTO no 3ph. I mow three acres. My main question is which one is the best value and would be worth more in 3-4yrs? I'm getting $3,300 on my trade and bringing $3,000 to the table total $6,300 for each option. What should I do looking for any help and advice.
   / new X540 or 2006 used x720???? #2
In this situation, I would suggest neither. Here is why.
The X540 is kind of, out to the pasture so to speak in terms of pricing. It is a VERY expensive lawn mower, and your still getting a riding mower, not a full blown garden tractor like the X7 series. It is still a belt driven deck, with a dry clutch. No hydraulics, and no shaft driven implements.
The engines in the X540 tractors are very good engines, but to be honest, I have read a lot of complaints over them. Some of those include excessive smoke, oil consumption, high fuel consumption, and general overall problems. There are some people on this board who have returned X540's to John Deere because of "gremlins" that could not be figured out in the machine.
Overall, I feel the X540 price is just way too close to an X700 series, to even consider the X540. If you step into an X720, your getting WAY more machine. One big plus on an X720 is fuel injection, so no carburetor issues.
The X720 IS a much better move, but I wouldn't suggest a 2006. Right now, John Deere is clearing out X700's like crazy. With a bit of shopping around, I would be willing to bet you could find an X720, new, or very close to new, for very close to the same price as a new X540. I just picked up an X740, and I can't tell you how glad I am that I walked right past the X500 series.
Keep in mind, this is just how I feel about the situation. If money is tight or you really don't want/need an X700 series, than that's up to you. If you do opt for the X500 series, I strongly suggest the X530, and not the X540.
   / new X540 or 2006 used x720???? #3
I agree with jdtank. This is one of those situations where personally I would have to eat another year or 2 payments and step up to the x700. However, you make no mention of doing anything but mowing. So if this is the situation, I see no reason that I would get rid of the machine your using now. especially with low hours. I mowed 2 acres for 10 yeaars on a jd 325 with 48 inch deck. Only reson I sold it last year was because I have over 10 acres now and needed a bigger machine
   / new X540 or 2006 used x720???? #4
The OP indicated he is mowing 3 acres.
With that kind of land to cover, your much better off with an X720. You will pile on the hours quite fast with that amount of grass. I only have 2.5 acres to mow, and I opted for an X740.
Value? There is no question, down the road, no matter what, the X720 will be worth more money. Even a high hour, fairly worn X720, will sell for more than a great condition, low hour X540.
I have never seen any machine hold it's value so well, as these X700 series do. They hardly lose any value.
   / new X540 or 2006 used x720???? #5
JD,
The thing is the GX345 only has 255 hours on it and unless their is some issue with it I think I would keep it and save a bunch of cash. Since the new diesel x7xx machines are rated at 24hp (below the 25 hp threshold) I would consider moving up after the bugs are worked out in a year or two.
   / new X540 or 2006 used x720???? #6
Well I might as well be the odd man out here. I had an X540 and loved it. High oil consumption? No (actually, none). Hard on gas? No. Did it smoke on start up? Sometimes but that had nothing to do with oil (as it was explained to me by the service manager). The motor is quiet and had lots of grunt. It was carbourated but so what. It had a 54" Edge which produced a good cut.
Now I own an X740. Do I like it better than the X540? Yes, some. I didn't really need it, just more of a want than anything else.
The 540 is a good capable machine. and like anything else there is bound to be a lemon in the works somewhere. I can't speak to the price differential since I bought my 540 used. I do know that for a mower it will be a first rate machine. For me probably would go for a new 540 before I bought a 7 year old 740 unless you are sure that you may want to eventually add some ground engagement implements.
I feel that sometimes we are too quick to spend someone else's hard earned money. Ultimately it it comes down to what you decide fits your needs and wallet better.
Just my $.02 worth.
   / new X540 or 2006 used x720???? #7
I must agree with Ron S I would buy a new X540...my thinking is was it really takin care of and was it operated properly!
   / new X540 or 2006 used x720???? #8
It is definitely a perk of buying new.
If you plan to just turn over the machine, and buy another one in 3 or 4 years, buying used is for you. If you want to keep it for a very long time, I think new is your best option. You can take care of it exactly how you want to, right from day one. There is also a special feeling you get when you know you are the only person who has owned that machine.
I suggest looking into a new X720 though, just so you know the dollars and cents of it.
Here is an example. 2012 X720 with only 75 hours on it. They are asking $7,490. I bet you could get it for $7,000 or so. The new X540 will equal that. At 75 hours the X720 is still brand new. I am not sure if I am allowd to post the link to this machine but here it goes.
https://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=7469345
   / new X540 or 2006 used x720???? #9
Just to answer your question, the X720 is going to be worth much more in 3-4 years than the X540. Reason being is because you're comparing buying new to buying used. The used X720 already took the initial hit in depreciation and will have very little loss over the next few years, where as the X540 is being purchased new, so it will take a big hit.
I would not trade the GX345 for an X540 for the simple reason that I believe the GX345 is a much better built machine. What's the benefit of getting the X540? Same size machine and cutting deck, so what are you gaining?
The X720 is another story. It's a bigger machine with a bigger deck, but what else are you going to use it for? If its ONLY going to be used to mow the lawn and NOTHING else, then you should be looking at a zero turn mower. They can't be beat for quality of cut and for how much faster they can get the job done. Once you use one, you'll never want to cut the lawn with anything else.
IF you do plan on using the new tractor for other things, such as pulling a wagon, tilling, aerating or snow blowing/plowing, then the X7xx series can't be beat.
Let us know what you decide and good luck.
   / new X540 or 2006 used x720???? #10
I think the best approach is to consider the tasks a machine is going to be required to do and total cost of the tractor and tools necessary to get it done. If you are considering a loader for example then only one of the two will do, however if mowing is all you need but need to cover more ground then maybe a trailer type mower in conjunction with the deck on the present machine will get the job done. The X5 (likely the GX?) series can be had with the sleeve type hitch so many tools can be used with the machine they just wont be of the 3pth type, which is not necessarily a bad thing depending on how often/duration they get used. If snow removal is a task, I believe there is a major price difference in blowers and blades between the two, and depending on the hours used for such "seasonal" tasks you might find your answers once you figure out the cost of the tractor and the required tools for your tasks. I think many apply the bigger is always better approach buy one of these super GTs and then find out tools for them are quite expensive also and get limited use of their machine because total costs get way to high for their budgets/cost tolerances. Just my opinion.
   / new X540 or 2006 used x720???? #11
JD,
That's what I think. Unless the GX345 is giving trouble I'd keep it. I keep talking myself out of moving up from an X720 to X740 just to save some gas. I'd never make it back in what it save over gas but there's the convenience of having a 500 diesel tank here on the farm. I told her to get the diesel to begin with but she didn't want it but that's another story.
   / new X540 or 2006 used x720???? #12
I know the feeling, I am in the opposite position. The only diesel machine I have is my X740, all the rest of my yard equipment is gas. I have to go out of my way to get diesel when I need it, as my station I purchase gas from does not carry diesel. However, it is still well worth it IMO. With the diesel option, you pretty much need to "buy it right" the first time, or else it's not justifiable at all. In 5 years when all of my debt is gone, I hope to pick up a 5085M. If I do that, I will have to purchase a bulk tank. There is no way I will stand at the gas station filling up 10 - 5 gallon cans!
   / new X540 or 2006 used x720???? #13
wow. x700 to a 5085? pretty extreme
   / new X540 or 2006 used x720???? #14
I looked at a 2008 x740 with very low hours, 62? deck almost never used and 3ph at $6500.
In the end I went with a brand new x740 with the 7 iron deck at right around $9700. I wonder what a new 720 with std yellow deck would go for right now? Surely under $9000 outright and 6 model years newer.
   / new X540 or 2006 used x720???? #15
The X740 is for finish mowing, and the 5M series will be for the heavy farm work. Buying more than you think you need is the best way to avoid being disappointed with performance.
   / new X540 or 2006 used x720???? #16
that's a big machine
   / new X540 or 2006 used x720???? #17
One big motivating factor for the 5M series is the price. You can get a 5M series for the same price, in some extreme cases even cheaper, than a 4720 compact utility. The 4x20 has a cramped cab because it has to fit on the 4x20 frame. The 5M series cab is a world of difference in size, layout, and noise reduction. You have to ask yourself, why would you buy a 4x20 series when you could get a 5M for the same money?
For me, I have no tight areas to get into, so size isn't much of a worry. I have always loved machinery as a kid, the bigger the better. I only have 8 acres, but what the heck, you only live once!
   / new X540 or 2006 used x720???? #18
I would like to know who is selling a 5085M for the price of a 4720?
   / new X540 or 2006 used x720???? #19
4720 cab -44.5k. 5075m cab-57k. 5085m cab- 60k. These are prices for just the tractor.
   / new X540 or 2006 used x720???? #20
Sorry, I should have specified.
You can get a 5065 for about the same money. I just WANT the 5085, but no, the 5085 cannot be had for 4720 money.
I seen a 5065 go at my local dealer about a month ago for 2,000 more than a 4720. I am not sure if it was a model clear out or what, but whoever bought it landed a good deal!
If you look on some of the online tractor sale sites, you can find 5065's for close to 4720 prices.
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
2017 FORD F350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F350 XL...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
