John deere 820
   / John deere 820 #11
What is involved with changing the o ring on the pto lever?
Removing 3 pt cover then removing spring pin to get shift lever out of trans case to renew o-ring and reassemble in a very hard to access place. A very difficult task.
   / John deere 820
Thanks for the help. Will keep y'all posted. Anything else I need to know about these little tractors?? Are they reliable?
   / John deere 820 #13
Very reliable tractor. Bought one in 1972 and still running good today. Good to use for grading, bush hogging, cutting and raking hay, etc. o ly real problem rear hydraulic leak as mention by others but not a major issue. Agree need two good batteries. What is overall condition of tractor? If you decide you don't want to keep it, let me know for I might be interested.
   / John deere 820 #14
I remember when I sold those 3 cyl 820's when they were new. First tractors I had sold that were built in Germany and I was very skeptical. They turned out to be very good tractors just deliver them & forget them hardly ever any warranty work was performed on them.
   / John deere 820
I will let you know. The tractor is in fairly good shape. Sheet metal is decent just missing battery cover and side screens. It has a new clutch that was installed three years ago. It spent most of its life on a ballpark running a finishing mower. Overall it's decent. It does have turf tires on the rear and will be looking to replace them with regular tractor tires. If anyone knows where I can maybe get the sheet metal parts I need let me know thanks.
   / John deere 820 #16
Every now and again you can find leads on on E-Bay. Ascension Equipment in Gonzales can get new but oh so pricey.
   / John deere 820
Thanks for the info. Hopefully this week I can work on it and see what it will do. Hopefully it will run ok
   / John deere 820
   / John deere 820
One more ques, where is the dipstick for hydraulic and transmission,
INBOARD DRIVE (A58374)
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
