Ford 841D - first tractor project (modifications)
   / Ford 841D - first tractor project (modifications) #31
that is amazing work , i would like to have mine like that .
I've been working off and on the last couple months on this tractor & since the internal hydraulics were weak (I wasn't sure at the time if it was the pump or the cylinder etc...). I have decided to make this tractor a dedicated TLB. (I've had the backhoe for a year & just now getting to it). Valves are in good shape on the BH, but my subframe is homemade, so I have had to modify the hook-up & that is still in progress.
It is still going to be removable, but I have no plans of doing that unless necessary. I already have a front mounted pump 23 gpm that I use with the MF 200 loader, so I have removed all internal hydraulics, boxed them in a Rubbermaid container & fabricated cover plates for all of it. I have a 5 gallon reservoir on the loader, but the specs for 713 call for about 12 gallons. I wanted to use the internal sump (and maybe rear axle)? for a reservoir. I know I've read about this being done, but I can't find any info. when I need it. I have ideas for plumbing it - I just wanted advice on the internal sump & maybe the rear housing as main res. There is no leakage between trans. & hydraulics. Presently, there is in rear end, because I removed PTO components for later use as well. (Built a cover plate for the side).
I've got some pictures of what I've done - any help on this project appreciated!
May 4th, 2013 backhoe work 003.jpgMay 4th, 2013 backhoe work 012.jpgMay 4th, 2013 backhoe work 015.jpgMay 4th, 2013 backhoe work 021.jpgMay 4th, 2013 backhoe work 023.jpgMay 4th, 2013 backhoe work 052.jpgMay 5th, backhoe work 010.jpgMay 6th, 2013 backhoe work 016.1.jpgMay 8th, 2013 backhoe work 035.jpgMay 8th, 2013 backhoe work 037.jpgMay 17th, 2013 backhoe work 002.jpgMay 17th, 2013 backhoe work 003.jpgMay 21st, 2013 backhoe disaster 003.jpgMay 21st, 2013 backhoe disaster 005.jpgMay 21st, 2013 backhoe disaster 007.jpgApril 30th, 2013 backhoe work 018.jpgApril 30th, 2013 backhoe work 021.jpgApril 30th, 2013 backhoe work 022.jpgMay 1, 20113 backhoe work 001.jpgMay 1, 20113 backhoe work 022.jpg
SoundGuy has helped me figure out the plumbing (using my old Hyd. sump as add-on reservoir). The main-frame is now modified to fit the tractor & it can be removed if necessary, but after the work is completed, I hope to seldom remove BH, FEl, or sub-frame. the 713 seemed to have issues with the main frame cracking (most all I have seen were patched), so I incorporated 1/2 plating down each side & 1/2 plating welded to the back of cab w/6 bolts on each side for support.
A little more bracing to do on the front side, but nearly finished with that. There is only going to be one seat - it is going to run on tracks (channel) & run up angle to backhoe controls (car seatMay 25th, 2013 - backhoetractor work 030.jpgMay 25th, 2013 - backhoetractor work 033.jpgMay 25th, 2013 - backhoetractor work 038.jpgMay 25th, 2013 - backhoetractor work 049.jpgMay 25th, 2013 - backhoetractor work 056.jpgMay 25th, 2013 - backhoetractor work 057.jpgMay 25th, 2013 - backhoetractor work 066.jpgMay 25th, 2013 - backhoetractor work 075.jpgMay 25th, 2013 - backhoetractor work 079.jpg motor). Then spin around & raise it to a comfortable level. (It kinda works like a ski lift). Hope to get control valve finished & start putting things back together.
   / Ford 841D - first tractor project (modifications) #34
Looking good, how much more before its finished?
You are very kind, I hope it will turn out the way I imagine it....
Varmint,
I hope to have the BH back operational by mid-June....(if everything goes smoothly). But as far as finished, LOL - at the speed I work, it could be this time next year...especially if I keep modifying the modifications....!
   / Ford 841D - first tractor project (modifications) #37
keep the pics coming!
   / Ford 841D - first tractor project (modifications) #38
wow this just keeps getting better very good attention to detail, very impressed with the hood.
After looking at the options for tapping into the sump for additional reservoir, I figured my best bet (shortest distance & largest opening) was to fabricate a blank plate cover to replace the existing relief valve cover. I figure I can weld black pipe with exactly the angle & drop needed to be a straight shot into main res. I also plan to use larger diameter pipe than the intake line to help assist flow (I've been reading the Womack hydraulics books for ideas & they recommend larger pipe). BTW, if you are like me & struggle with tractor hydraulics - Womack's books can really help, especially understanding basic concepts.
I've added a few pictures of the relief valve & it's cover plate (excuse the mess in there, it's getting cleaned up).
I also experimented with paint, so I did a wee bit of priming as well. Here's a few of those pictures as well. But, I must confess I have batted around several ideas for paint scheme & after this first attempt - I have decided to go back closer to my original paint scheme. (It isn't traditional...I hope that won't offend anyone). I just don't have the knowledge or expertise to get the paint colors to match original, so I'm going to be doing some more tests on the paint....but I don't want to get sidetracked on that too much yet.
May 28th, 2013 - tractor-backhoe work 003.jpgMay 28th, 2013 - tractor-backhoe work 005.jpgMay 28th, 2013 - tractor-backhoe work 006.jpgMay 28th, 2013 - tractor-backhoe work 009.jpgMay 28th, 2013 - tractor-backhoe work 023.jpgMay 28th, 2013 - tractor-backhoe work 031.jpgMay 28th, 2013 - tractor-backhoe work 032.jpgMay 27th, 2013 tractor work 016.jpgMay 27th, 2013 tractor work 019.jpgMay 27th, 2013 tractor work 029.jpgMay 27th, 2013 tractor work 045.jpg
Just to clarify, I'm cutting a hole in the blank plate to weld the pipe! The original & the relief valve are stored for future use.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
(INOP) JOHN DEERE 790 TRACTOR (A51243)
(INOP) JOHN DEERE...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
