How to lift filled rear tires
   / How to lift filled rear tires #21
Would like to here more about that operation .
   / How to lift filled rear tires #22
" the first tire would hit the ground and prevent the axle from turning".
Like I said take the tractor out of gear.
Pan
   / How to lift filled rear tires #24
I'm young strong and healthy and could easily handle those tires by hand, but why would I want to. Love the tool you've made. Just a thought, would the rollers have even helped to rotate a ag bar tire, probably not. Great way to save the back. Work smarter not harder was always dads motto.
   / How to lift filled rear tires #25
Bumpkin...being young, strong, and healthy is good; being smart on top of that is even better.
   / How to lift filled rear tires #27
Why not lower the tractor to the rim height? At least that is what I do if I have to take the rim off a tractor or combine
Ahhhh,,,,,,, a thinking man
Did lower the tractor the first time, if you read it. Works fine for the first tire, and like crap for the second one as the first one interferes with the ground while trying to line it up, and then you can't turn the wheel. I've tried turning a wheel on a car when only one is in the air before. Couldn't do it, even in neutral. But easy to do with both wheels in the air. I have no reason to think this would be any different, and so did not try it.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Champion Gas Powered Auger (A57454)
Champion Gas...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
New/Unused 110V Diesel Pump with 50ft Hose (A57454)
New/Unused 110V...
John Deere Z320R Zero Turn Mower (A57453)
John Deere Z320R...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
