BX has skid plate, but still lost all the blades from the HST driveshaft fan
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #11
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #12
Does anyone know what the difference between the brotech plates vs the bx expanded uderarmor plate? I don't really care about leaving a plate in place when mounting the mmm, I like the look of the bx expanded plate better. Any one have experience with the bx expanded plate? Thanks
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #13
I've had the opportunity to replace my HST fan as well, and this seems to be a common problem with anyone who actually uses their BX as a tractor vice lawnmower going back many years. There are plenty of good aftermarket and DIY solutions, but no good solution from Kubota, even on this year's updated BX's. Has anyone from Kubota, on this site or another, ever addresses this issue?
I'm starting to wonder if I should have bought a B series or maybe a green tractor instead.
Mike
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #14
I was reading about the BX fans on another forum and a poster said the yammer/JD has the same problem. Plus you have to do much the same routine to grease a CV joint.
Sorry I do not have that link at hand.
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #15
Mike
Your BX will be fine, just get the skidplates(all 3) for it. The reason it's such a big deal is that on the BX, the engine needs to be moved to replace the fan blade.
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #16
Thanks Don, skid plates are on order for mine.
Mike
   / BX has skid plate, but still lost all the blades from the HST driveshaft fan #17
I don't understand why Bro Tech or somebody doesn't make skid plates for Mahindra. I wish the manufacturers had used a cooler similar to the one on my Hustler Super Z, that vulnerable fan seems like a poor idea.
yellow ball Trailer (A56859)
yellow ball...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bobcat MT85 (A60462)
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2020 Deere 544L (A60462)
2020 Deere 544L...
