terramite t5c
   / terramite t5c #1
candp
prescott,wa.
1992 t5c terramite
anyone have model numbers for eaton or cessna transmission replace thks
   / terramite t5c
need to replace pump have no serial numbers they were sanded off helpppppp plz
   / terramite t5c #3
I'd suggest calling terramite or visiting a dealer. I wish I could help but they aren't real popular on this forum
   / terramite t5c
wa. state no dealers so far.need someone to check numbers off their machines
   / terramite t5c #5
Yeah the closest dealer I could find to the west coast is in New Mexico, parts availability for these machines is lame at best.
   / terramite t5c
found them!cessna-usa 70111-302-c needs squash plate and rotating group-could go new eaton 70160-lba-03 this would have everything including gear drive and coupling for engine 1,100 1200 with shiping
   / terramite t5c #7
all my hydraulics are working just cant go forward or backwards without grinding noise and it wll die if u press hard on the pedal.Is ths the transmission or what? Are we talking 1000.00 to fix this? Parts? I have the T5C 199 model. any ideas or thoughts?
   / terramite t5c #8
You might check the suction line. possiblity your sucking air. I have an Allmand that does the same thing after it is warm and I found the suction line was loose. I don't have it back on line yet to see if that was the problem.
   / terramite t5c #9
where is the suction line on the T5C model located? That could be a quick fix huh? pls advise.:thumbsup:
   / terramite t5c #10
It would be the large line going from the hydraulic oil to your pump. I think on the termite both ends go to a barb fitting. Also you should have a suction strainer at the hydraulic oil tank.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
