terramite t5c
/ terramite t5c #1
candp
prescott,wa.
1992 t5c terramite
anyone have model numbers for eaton or cessna transmission replace thks
/ terramite t5c
need to replace pump have no serial numbers they were sanded off helpppppp plz
/ terramite t5c #3
I'd suggest calling terramite or visiting a dealer. I wish I could help but they aren't real popular on this forum
/ terramite t5c
wa. state no dealers so far.need someone to check numbers off their machines
/ terramite t5c #5
Yeah the closest dealer I could find to the west coast is in New Mexico, parts availability for these machines is lame at best.
/ terramite t5c
found them!cessna-usa 70111-302-c needs squash plate and rotating group-could go new eaton 70160-lba-03 this would have everything including gear drive and coupling for engine 1,100 1200 with shiping
/ terramite t5c #7
all my hydraulics are working just cant go forward or backwards without grinding noise and it wll die if u press hard on the pedal.Is ths the transmission or what? Are we talking 1000.00 to fix this? Parts? I have the T5C 199 model. any ideas or thoughts?
/ terramite t5c #8
You might check the suction line. possiblity your sucking air. I have an Allmand that does the same thing after it is warm and I found the suction line was loose. I don't have it back on line yet to see if that was the problem.
/ terramite t5c #9
where is the suction line on the T5C model located? That could be a quick fix huh? pls advise.:thumbsup:
/ terramite t5c #10
It would be the large line going from the hydraulic oil to your pump. I think on the termite both ends go to a barb fitting. Also you should have a suction strainer at the hydraulic oil tank.
/ terramite t5c #11
where & what exactly is the suction line? I have had this tractor for many yrs but I dont live in the area where I bought and had it serviced. Plus I'm a female that really doesnt know the ins & outs of this unit. Have to have it "spelled out" in simple terms. I do know where the hydraulic fluid tank is. I see the big lines coming out of the tank. thks again. Any help is appreciated. KL
/ terramite t5c #12
I suggest you go to Terramite.com and download the parts manual for your t5c. This will help a lot in identifying different parts. I don't have my unit up and running, so I don't know if a loose suction hose is the answer.
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
207278 (A52708)
207278 (A52708)
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
TRANSFER PUMPS ON SKID (A63569)
TRANSFER PUMPS ON...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2019 C&M TRAILER 18' T/A UTILITY TRAILER (A63569)
2019 C&M TRAILER...
