terramite t5c
/ terramite t5c #1
candp
prescott,wa.
1992 t5c terramite
anyone have model numbers for eaton or cessna transmission replace thks
/ terramite t5c
need to replace pump have no serial numbers they were sanded off helpppppp plz
/ terramite t5c #3
I'd suggest calling terramite or visiting a dealer. I wish I could help but they aren't real popular on this forum
/ terramite t5c
wa. state no dealers so far.need someone to check numbers off their machines
/ terramite t5c #5
Yeah the closest dealer I could find to the west coast is in New Mexico, parts availability for these machines is lame at best.
/ terramite t5c
found them!cessna-usa 70111-302-c needs squash plate and rotating group-could go new eaton 70160-lba-03 this would have everything including gear drive and coupling for engine 1,100 1200 with shiping
/ terramite t5c #7
all my hydraulics are working just cant go forward or backwards without grinding noise and it wll die if u press hard on the pedal.Is ths the transmission or what? Are we talking 1000.00 to fix this? Parts? I have the T5C 199 model. any ideas or thoughts?
/ terramite t5c #8
You might check the suction line. possiblity your sucking air. I have an Allmand that does the same thing after it is warm and I found the suction line was loose. I don't have it back on line yet to see if that was the problem.
/ terramite t5c #9
where is the suction line on the T5C model located? That could be a quick fix huh? pls advise.:thumbsup:
/ terramite t5c #10
It would be the large line going from the hydraulic oil to your pump. I think on the termite both ends go to a barb fitting. Also you should have a suction strainer at the hydraulic oil tank.
/ terramite t5c #11
where & what exactly is the suction line? I have had this tractor for many yrs but I dont live in the area where I bought and had it serviced. Plus I'm a female that really doesnt know the ins & outs of this unit. Have to have it "spelled out" in simple terms. I do know where the hydraulic fluid tank is. I see the big lines coming out of the tank. thks again. Any help is appreciated. KL
/ terramite t5c #12
I suggest you go to Terramite.com and download the parts manual for your t5c. This will help a lot in identifying different parts. I don't have my unit up and running, so I don't know if a loose suction hose is the answer.
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2008 JLG 800S MANLIFT (A63569)
2008 JLG 800S...
Hyster H80XM Lift (A64047)
Hyster H80XM Lift...
2†Plowing Hook (A64047)
2†Plowing Hook...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
GMC 6500 (A63291)
GMC 6500 (A63291)
