Driveway SCRAPER or Driveway GRADER ?
/ Driveway SCRAPER or Driveway GRADER ? #21
After using a landplane for awhile, the jury's still out for me on the whole idea in general. Although the landplane requires less operator input, I can run box blade and get the same results. Actually, I think a landplane would work fine with just one centered / angled blade.
Not to argue with you, (well maybe, no not really), :D but I can get the same results also, but not nearly as fast. ;) Are you talking about grading or maintaining a road? The double blades take care of wash boarding in a road, where as with only a single blade, while it probably would work to get rid of the wash board, twin blades do it that much faster.
Just my :2cents:
/ Driveway SCRAPER or Driveway GRADER ? #22
It seems like some of the landplanes with multiple blades (most of them?) are also relying on the blades as structural members. There is no other support on the bottom portion of the landplane, towards the back, aside from the blades.
On my LPGBs, the blades are fastened to 5/8" x 6" angle. I don't think that there needs to be anything else, not with mine anyway. ;)
/ Driveway SCRAPER or Driveway GRADER ? #23
Just my :2cents:
Argue away Brian. :D Actually, I respect your opinion on the subject and I respect Steve's too.
I agree that for washboard, the double blade is probably a plus. In fact, I'll take your word for it. We don't really get that around here, but being from the So Cal Acton area I do understand. (I get your dirt :D).
Around here with our clay (calling it dirt is questionable) and limestone road base, potholes are the real problem. The ground pumps and holds water in spots and then sinks below the road. Dragging a landplane up and down the driveway just fills up the holes with loose material, makes it look pretty and then the potholes return in the same spot a few weeks or months later. For re-grading a road here, rippers and a box blade work faster and better for me.
What do I know...I'm an old skiploader hand...so shoot me. :laughing:
I'm going to grade out a couple of select fill pads and FORCE myself to use the landplane (with blades set flush) instead of the box blade to spin 'em out. I'll get back to you on my opinion.
/ Driveway SCRAPER or Driveway GRADER ? #24
That's what I was referring to, as far as adding structural stability. Meaning that the blades being there, are what add to the structural stability, because without the blades, there would be no need for the angle iron it's bolted to. :D
I should have explained it better, I'm not too good at doing that :laughing:
/ Driveway SCRAPER or Driveway GRADER ? #25
Hey gang, I know the whole drievway scraper discussion has been leveled off quite a bit :laughing: BUT I havent seen anyone suggest something like the Agritek scraper. I have a few driveways and two small parking lots that would need leveled. My personal driveway doesnt pothole but with the rain I get a little washout in certain places. BUT I do have two driveways that tend to pothole get a little uneven. I typically will crown the driveways by angling my 3pt scraper blade to the center then grab a higher gear with the blade straight across and let the blade ride up. It does a pretty good job but it tends to not crown out far enough to get the water off the drive.
I like the landpride driveway grader but I dont like that the spill off is both on the one side, and that is where I like the Agritek style driveway scraper. They are both priced about the same only but the Agritek is 72", 96" and the LandPride is 72",84", 96"
Agritek Industries | Michigan Manufacturing - DS Driveway Scrapers
GS25 Series Grading Scrapers | Land Pride
Ian,get the landplane.I bought a Befco landplane last year,it works great. Stop by and see how it works.Frank
/ Driveway SCRAPER or Driveway GRADER ? #26
When I bought my land plane, I had to deal with deep pot holes. I bought the Land Pride because it had the rippers so I can rip down as deep as I need.
For quick touch ups, like I am going to do this weekend, I leave the rippers up.
The scarifiers give me ability to rip up like a box blade, and the plane gives me the speed, control, and ease of use that I was looking for.
I really enjoy working with this tool.
/ Driveway SCRAPER or Driveway GRADER ? #27
I don't have rippers on either of mine but agree that having them on a landplane would be a big plus.
/ Driveway SCRAPER or Driveway GRADER ? #28
The BEFCO has an inner frame that's adjustable. The blades mount to the inner frame and the whole thing can be moved up and down. The outer frame is made up of the sides, the cross members, and the 3pt mounts. The front cross member is extra heavy as it also holds the rippers. I think the Woods and Land Pride also are like this.
/ Driveway SCRAPER or Driveway GRADER ? #29
Can anyone post a picture of this "inner frame"? I'd like to see how that works.
Thanks sir! I will have to stop in!
/ Driveway SCRAPER or Driveway GRADER ? #33
So far the only issue I have is I have worn out the steel skids on my BEFCO. They are easily replaced but I decided to hard face them by welding them. We'll see how well that works. It was the front corner that got the most wear so I could have reversed them. Messicks has them for $33 each.
would that be due to the top link being too short on your 3 point? seems like the skid pads should wear even and the cutting edge on the land plane would be taking the brunt of the wear?
/ Driveway SCRAPER or Driveway GRADER ? #35
When you use the rippers it wants to tip the GS onto the front edge. Keeping your top link the correct length helps a lot. But any play in both the top link and bottom arms comes into play. Since the BEFCO is set up so someone with a quick hitch can use it there's some play. I made some spacers for the top link to keep it centered. Since my drive is not flat it's not as easy as setting the top link and forgetting about it. Also I wasn't as good as I should have been keeping the nut on the top link tight. Remember the rear lifting 1/4" over a 4' span works out to be about 1/16" of an inch of play if your top link and bottom arms are a foot apart so the slightest bit of play or not level and you'll wear the front edge. But over the 3 years I have had my BEFCO I have used it about a dozen times a year. What I don't know is if using it on hard packed dry gravel (something I do too often because of free time restraints) wears it more than waiting until after some rain when things are softer.
Both the blades and rippers show almost no wear.
/ Driveway SCRAPER or Driveway GRADER ? #36
It's been my experience that filling potholes with loose material only causes the potholes to come back in a few weeks. The loose material just doesn't bond to the other material which necessitates the use of rippers to loosen the materials to at least the depth of the potholes before grading. Compacting a freshly graded driveway is advisable too.
/ Driveway SCRAPER or Driveway GRADER ? #37
I'm looking to buy a land plane or have one built with rippers for my tractor. I've always has construction equipment for my raod maintenance before, so I don't have a lot of experience with lan planes. Most of the land planes I have seen have pretty short skids. Why is that? I would think a longer skid (not wider) would be better at taking out rises and dips. Is it that most only use them for filling in potholes and washboards instead of re-grading like I'm thinking of doing? It seems to me that 8-10ft long skids on a 50hp tractor would be ideal. Please advise! :)
/ Driveway SCRAPER or Driveway GRADER ? #38
Old thread but good discussion... I agree with you Danny. But would like to add that the land plane grading scraper should be doing a lot more than moving around loose surface material to fill in low spots. If it is working right it cuts down into the road leaving a hard flat under surface with a loose layer of freshly mixed gravel on top which should be compacted for best long lasting results. The trick with pot holes is to go over them with the LPGS when they are first forming so you can cut down to the bottom. For your own road that should be no problem. For comercial work you probably won't be called until the drive needs serious work and is beyond using just a LPGS for repair.
/ Driveway SCRAPER or Driveway GRADER ? #39
I don't have to deal with pot holes much in my locale but agree that ripping them is important.
About the skid length, most are short to save money and make shipping size easier to deal with. Making the skids too long can make the landplane cumbersome to deal with too. Both of my current landplanes have 60" running surfaces one is 4' wide and one 8' wide. If all I used them for was driveway touch ups I would prefer longer skids on the 8' landplane, maybe 6' skids. I am not sure you would benefit that much more having 10' skids in most cases as it would be very cumbersome and the added weight you would need to maintain ground contact might be more than a 50 hp tractor can handle.
As Gordon mentioned you have to trim the toplink when using the landplane and having the skids too long would make this difficult.
/ Driveway SCRAPER or Driveway GRADER ? #40
Gordon,
You bring up a good point about commercial work, I suspect that is the case for RDRancher in that he is called in to perform a major overhaul of the roads and needs to cut them deeply to get to the bottom of the pot holes. Landplanes make more sense for routine maintenance imo, once you get the road in shape try to keep it that way.
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
2013 Ford F-550 Passenger Bus (A59230)
2013 Ford F-550...
Metal Transport Rack (A59228)
Metal Transport...
BUNDLE OF UNION STRUT COVERS (A60432)
BUNDLE OF UNION...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
