Sorry for a delay responding but here is the JD Tech bulletin on this very subject. the picture it refers to  shows similar to AKFish's pictures above.
"Solution Number: 84010
Solution Summary: 5X25|5E|5E Limited|5M - DANA 725 MFWD Axle Grease Zerk Locations
Publication Date: Jun 12 2009
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom :
Maintenance Guide shows that the MFWD King Pins Pivots require lubrication every week/50 hours.
Problem or Situation :
Customer cannot locate the grease zerk locations shown in the manual for the MFWD King Pin Pivots.
Solution :
The DANA 725 MFWD Standard Axle does not have any grease zerks for the King Pins. King Pin pivots use tapered roller bearings which are sealed for life. On the DANA 725 the only grease zerks are located on the Trunnion as shown in the picture below.
LEGEND
A - Trunnion Grease Zerk Locations
Additional Information :
Please print this DTAC solution for your customer's as a supplement to their maintenance guides.
5225, 5325, 5425, 5525, 5625, 5101E, 5045E, 5055E, 5065E, 5105M, 5075E, 5083E, 5093E, 5095MH, 5065M, 5075M, 5085M, 5095M
AXLE, TRAC PT, 021"
