dongfeng tractor with y385t wont start help
   / dongfeng tractor with y385t wont start help #12
It's not uncommon for them to leak a little while pumping because there is no seal in the piston. Just so they don't leak when screwed down, that's the main thing.
well i put a few gallons of fresh diesel in the tank and let it run thru the line a bit then installed the banjo bolt, pumped the hand pump around 30 times, then loosened each hard line at the injector one at a time and turned it over untill fuel spirted out then hit that hand pump again maby 30 or 40 times and it never got tight the first time or this time, but i tryed to start the eng and it still was a no go, then i drained the oil out of the motor to see if I was missing some rad fluid that might be getting in there from a blown head gasket and the oil was black and no water, could I have a bad injector or a few of them and thats what wont let it run ?
also does anyone know of replacement filter numbers from wix or any other company for the oil and fuel filter thanks
   / dongfeng tractor with y385t wont start help #15
A 3 cylinder diesel can start/run on only one cylinder. Rough and smokey, but it runs. I've seen it happen on mine in very cold weather. One cylinder will catch, then in a few seconds another and another will catch as their cylinder temps rise from the repeated compression. Whatever your problem is, seems common to all three cylinders. Given that it sat idle for so many years, I suppose there's a chance that all 3 injectors have gummed up - or even rusted shut.Think I may have seen someone earlier recommend you remove the fuel injectors - and reattach the hard lines - to see if the injectors actually pop/spray when you crank the engine. Have you tried that yet?
//greg//
   / dongfeng tractor with y385t wont start help #16
...recommend you remove the fuel injectors - and reattach the hard lines - to see if the injectors actually pop/spray when you crank the engine. Have you tried that yet?
//greg//
I agree. If there is no spray pattern, or if they dribble inbetween "pops" they need to be replaced. These injectors are inexpensive so it's not economical to take them to a diesel shop for cleaning.
ill give that a try next, is there crush washers that i will have to reinstall under the injectors after taking them out, and does anyone know of any after market fuel and oil filter numbers for the y385t thanks again everyone for the help
   / dongfeng tractor with y385t wont start help #18
I have the conversion numbers for american filters-belt-radiator cap, also the fluids. Give me a call and I can give them to you
Nan
Parts Dept.
Keno Tractors
   / dongfeng tractor with y385t wont start help #20
Yes, there are copper washers under the injectors which can be re-used if they are clean and still soft. Make sure the injector bores are very clean.
Not sure about filter crossover numbers because some filter heads are metric and some are SAE straight thread. Also, some filters have domed thread bosses and others don't. Best to find out which you have before calling a parts house.
2012 SCOTT MANUFACTURING  CONVEYOR TRAILER (A55745)
2012 SCOTT...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2017 Ford Transit Connect XL Cargo Van (A55852)
2017 Ford Transit...
2013 HERCULES ALUMINUM KILL TRAILER (A55745)
2013 HERCULES...
PALLET OF (2) COMPRESSORS (A55745)
PALLET OF (2)...
KENWORTH ROLLBACK TOW TRUCK (A57192)
KENWORTH ROLLBACK...
