rsallen
And please reread mine.
If my NH shuts down with the key, then it has electric solenoid someplace in the system. Probably much like cars, it's on the fuel pump that activates a rod internally.
If I have to, I'll go out and find exactly where it is and let you know where it's located because the tractor shuts down the fuel with the key.
I asked the op because I didn't how his how tractor was set up is all.
As everyone is giving their creds in this post, I've worked in the automotive field for 45 + years and owned my own shop for 30 + years.
I tried to help the op with his diesel problem, but as everyone knows more about engines and fuel than I do I'll bow out of this thread now.
It's too bad though the op didn't do a leak down test before tearing it apart so he'd know just how far he's going to have to tear the engine down before he puts a head back on to find out he's also got wasted rings.
Order of diagnosis goes, fuel check, compression test (comes out badly), check valve train - all is well, leak down test........tear apart as necessary.
Save that for future reference everyone.
Wheather you're a so called called mechanic or not.
