Best Spray on Bed liner
   / Best Spray on Bed liner #41
My 08 Titan has factory sprayed in liner. All Nissans 2003 and later have it. Noy sure why they are the only ones doing it factory? Seems like a no brainer to me. They also put in a rail system with movable tie down points. Another smart idea.
Anyways, 72,000 miles and it still looks great.
Chris
Ford and Ram offer factory spray ins.
   / Best Spray on Bed liner #42
If they are oveypriced like many other factory options, i'd go aftermarket, Unless OEM is that much better?!
   / Best Spray on Bed liner #43
Ford offers it from the factory now. Maybe they spray it post-factory, but you can order a truck with it, and it is done before it hits the dealer.
Chris
Ford offers it. I found a truck that I liked and it had the spray in bed liner but it had 3.55's. I found a truck equipped the same but no liner with 3.73's which gives a good bump in towing capacity. I one advantage to the aftermarket is the lifetime warranty. The factory spray in liner did look nice. I think it is a $410 option. I called linex today they are $460.
   / Best Spray on Bed liner #45
I had the inside of my dump body done with Linex. Mainly because I use straight salt in the winter in my sander. It held up well and things still slid out fine when I tipped the body up. I have another truck on the way next week that the dealer had sprayed with Rhino, I have never had that material before but looked at a few on the lot and they appeared to be good quality. My Linex did fade a bit, that was not a real big concern of mine. I spoke with both the Linex and Rhino guys and they both said the biggest factor is the installer. If the truck is not prepped correctly, there will be problems.
   / Best Spray on Bed liner #46
Not in 08 and surely not in 03.
Honestly, I am a Ford Man, but if Nissan would have done a better job at marketing the Titan would have been a huge hit. They had features the others did not for 5 plus years.
Chris
   / Best Spray on Bed liner #47
I put a rustoleum kit on my trailer a year ago..It sits outside and hasn't faded or scratched after some rough use...I did spend some serious prep time on it, but it's holding up very well.
I have 18" sides that I coated the inside and over the top lip...Time will tell how well it does..Better than nothing I guess.
I thought about getting a kit do do a trailer but I cheeped out and painted it instead. I think I am going to go with linex, I need to make a appointment.
   / Best Spray on Bed liner #49
I think the whole kit cost about $125...I'm happy with it so far. Roller on thing.
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
