Best Spray on Bed liner
   / Best Spray on Bed liner #41
My 08 Titan has factory sprayed in liner. All Nissans 2003 and later have it. Noy sure why they are the only ones doing it factory? Seems like a no brainer to me. They also put in a rail system with movable tie down points. Another smart idea.
Anyways, 72,000 miles and it still looks great.
Chris
Ford and Ram offer factory spray ins.
   / Best Spray on Bed liner #42
If they are oveypriced like many other factory options, i'd go aftermarket, Unless OEM is that much better?!
   / Best Spray on Bed liner #43
Ford offers it from the factory now. Maybe they spray it post-factory, but you can order a truck with it, and it is done before it hits the dealer.
Chris
Ford offers it. I found a truck that I liked and it had the spray in bed liner but it had 3.55's. I found a truck equipped the same but no liner with 3.73's which gives a good bump in towing capacity. I one advantage to the aftermarket is the lifetime warranty. The factory spray in liner did look nice. I think it is a $410 option. I called linex today they are $460.
   / Best Spray on Bed liner #45
I had the inside of my dump body done with Linex. Mainly because I use straight salt in the winter in my sander. It held up well and things still slid out fine when I tipped the body up. I have another truck on the way next week that the dealer had sprayed with Rhino, I have never had that material before but looked at a few on the lot and they appeared to be good quality. My Linex did fade a bit, that was not a real big concern of mine. I spoke with both the Linex and Rhino guys and they both said the biggest factor is the installer. If the truck is not prepped correctly, there will be problems.
   / Best Spray on Bed liner #46
Not in 08 and surely not in 03.
Honestly, I am a Ford Man, but if Nissan would have done a better job at marketing the Titan would have been a huge hit. They had features the others did not for 5 plus years.
Chris
   / Best Spray on Bed liner #47
I put a rustoleum kit on my trailer a year ago..It sits outside and hasn't faded or scratched after some rough use...I did spend some serious prep time on it, but it's holding up very well.
I have 18" sides that I coated the inside and over the top lip...Time will tell how well it does..Better than nothing I guess.
I thought about getting a kit do do a trailer but I cheeped out and painted it instead. I think I am going to go with linex, I need to make a appointment.
   / Best Spray on Bed liner #49
I think the whole kit cost about $125...I'm happy with it so far. Roller on thing.
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2010 International 4400 National Crane 300C 56ft 8 Ton Crane Truck (A50323)
2010 International...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
