New Home Begins
   / New Home Begins #581
I was wondering about that. I saw the sand, but no mound. I have never seen one where it did not look like a submarine was buried in the yard. I have always wondered why they don't allow the removal of a large area of original soil and replacing it with sand. That type of system has become very popular in our area. The standards to meet the perc tests have gotten so restrictive that it is often the only way to get a system. It also happens in our area when it is time to replace an existing system. There are people have been in their house for 40 years and suddenly end up with the unsightly mound in their front yard. Do you have any idea how much more that system costs than a conventional drain field? We have had pumped fields at the last 2 houses so that the system can exist in the highest and driest part of the yard. I wondered if the premium (short and long term) of the pumped system is the same or higher than the sand mound. I think our pumped system cost us a $5500 premium!
Lee
The reason they are mounded up has to do with the depth of suitable soil to clean the effluent, 7' was mentioned in my area. The sand even has to be certified for this use.
   / New Home Begins
They use that type of drainage tunnels around here, in single trenches.
Are you required to have a filter before the drain feild?
Dave
I am not sure about required by code, but there is a filter in the tank that needs to be pulled out and hosed off quarterly.
   / New Home Begins
Same here. The sand for septic systems in south jersey pretty much comes from one place. It even has to be tested and certified regarding pesticides and other contaminants.
   / New Home Begins
Lots going on but I have been too busy to take photos. All hardwood flooring is in. Kitchen cabinets, spacers, appliances are all in. Only a few electric circuits left to hook up. Granite countertops are in. All permanent lighting is finished. Toilets and vanities are in but still need to hook up the faucets.
P1030070.jpg P1030071.jpg P1030072.jpg P1030083.jpg P1030084.jpg P1030086.jpg P1030089.jpg P1030091.jpg P1030092.jpg
   / New Home Begins #587
The granite is very cool. Tom, will you put a granite backsplash on also? If not, what will you use that won't clash with that granite? All the pieces are sure coming together nicely. I am a little surprised that you didn't opt for a double sink, but if you rinse and go straight to the dishwasher, a single sink may be plenty. It does leave you with more counter space.
   / New Home Begins
Thanks! Yes, we will be putting in a backsplash after we get in and see what will work best. As for the double sink, there was no room. There is a 36" corner lazy susan, 2" spacer, 27" sink base, dishwasher then refrigerator. There was no way to work in a wider sink. We love the D sink too.
   / New Home Begins
Today, we got the water hooked up. Well manifold to water filter, filter to cold supply, 80 gallon electric hot water heater. I had to run new electric line (10-2) since I only ran a 12-2 for the water heater as we wanted a propane water heater. Unfortunately, a power vent hot water heater requires 4' clearance to operating windows and that side of the house is all windows and doors. We would be pushing the limit to run 3" PVC venting all the way to the other end of the house. We also installed the main bath vanity top, caulked the main bath, installed the kitchen faucet.
Tomorrow's task include drill through the basement wall to connect the 4" main drain to the new septic system. If time allows, get the kitchen sink drain installed and main bath faucet and drain.
We are pushing to have the final plumbing inspection on Wednesday.
   / New Home Begins
It's been awhile but we are getting to the finish line. We received the final electric approval as well as the final plumbing. Propane is to be installed on Monday and I will request the inspection for that for Wednesday. (M-W-F only for plumbing). Once I have that, I can request the fire inspection.
Still to do:
Well testing - Monday
Pour the front steps - Tuesday.
Porch railing - Wednesday
Baseboard and door/window casings.
Grading and stone for driveway - later in the week.
We installed all of the interior doors this week. Two panel, arched top, V-groove knotty pine.
We built the railing protecting the stairs today. Cedar posts and rail, wrought iron balusters. Sorry for the poor quality pictures but that's the difference between a real camera and a smartphone.
The masons have finished the fireplace. The wood in the wall is the placeholder for the real mantel that is not in yet. It will be 4" x 8" x 56" with some small corbels under it. Sorry for the tilted photo.
378748 (A51573)
378748 (A51573)
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
